boost taper with MBC @ 22psi
Old Jun 14, 2007 | 12:37 PM
hellcat's Avatar
Edited edited edited.
Old Jun 14, 2007 | 12:39 PM
sekula's Avatar
if your set at 22, you'll probably taper to about 20ish...
Muad's Avatar
Originally Posted by hellcat
How much does the boost taper on average for an evo set to 22 psi?
+1
Old Jun 14, 2007 | 12:40 PM
Thegame's Avatar
yeah, I think you figure about a 2 psi taper on a stock turbo / WGA evo.
Old Jun 14, 2007 | 12:46 PM
hellcat's Avatar
Thanks guys!!!
Old Jun 14, 2007 | 12:50 PM
topnitroracer's Avatar
With a IX you will taper more than a VIII. Depending on your set up and what you consider 22psi (spike or level out) you might taper down to about 18psi by 7000rpm.
Old Jun 14, 2007 | 12:55 PM
Murf's Avatar
a friends IX maxed at 22 then tapered to 16. My 8 holds 21 until about 6200rmp then drops 2 psi.
Old Jun 14, 2007 | 01:06 PM
cfdfireman1's Avatar
Depends on cams etc.
Old Jun 14, 2007 | 01:23 PM
rr06rs's Avatar
Also depends if you're on the stock dv and how well it's holding boost as well.
Old Jun 14, 2007 | 01:28 PM
666 EVO's Avatar
My IX is set at 21 and I fall to 19.
