question for the masses
Old Jun 23, 2003 | 02:49 PM
six's Avatar
six
ok, I am the first to admidt that I dont know too much about cars, and this is something that has been bugging me for a while.
Honestly, what is the defference between 4 wheel drive and All wheel drive? I really dont get it. if someone could explain the difference for me, thanks.
Old Jun 23, 2003 | 03:06 PM
Mister2zx3's Avatar
It's more of a nomenclature designation by a manufacturer, but for the most part all wheel drive is considered to be driving all the wheels *all the time*, many 4wd systems are selectable, so that it's 2wd when in that mode and 4wd when switched to that mode. Most offroad consumer vehicles use this so that they can get good gas mileage and less weat and tear on the vehicle under normal onroad driving conditions. Then when they want to go offroading and climb up some cliffs, they can stop switch it to so all wheels are engaged and driven, and often in a special lower gear for crawling up steep inclines.
Hope that helps..
Old Jun 23, 2003 | 03:10 PM
veritech137's Avatar
Hope that helps..
Exactly
Old Jun 23, 2003 | 03:21 PM
tryandcatchme's Avatar
Four-wheel drive - a part-time system. Part Time systems are meant only for use in low-traction conditions, such as off-road or on snow or ice.
All-wheel drive - All-wheel-drive systems are designed to function on all types of surfaces, both on- and off-road, and most of them cannot be switched off.
Old Jun 23, 2003 | 03:41 PM
leonard_shelby's Avatar
not to mention on some 4wd systems its the front drivers side and rear passengers side wheels are driven
Old Jun 23, 2003 | 03:45 PM
SRD's Avatar
SRD
4 wheel drive vehicles need to be shifted into 4 wheel drive, and will lock the front and rear axles, so front and rear wheels will turn the same speed.
AWD - has a center differential that can vary the amount of torque transfered to the front and rear wheels...does not neccesarily turn the same speed.
thats the general gist of it all.
Old Jun 23, 2003 | 04:44 PM
six's Avatar
six
thanks guys, that really helped
