Intake Flutter? [NEED HELP ASAP]
Old Jun 17, 2007 | 09:21 PM
EVORaab's Avatar
Question Intake Flutter? [NEED HELP ASAP]
Yo guys my EVO 8 is making a terrible flutter that sounds like a damn turkey call when i let off the gas at any RPMs.
It had a typhoon intake kit, which I took off put on the stock intake and a new stock blow off valve and then a buschur intake cone.
it is still making the damn flutter noise!! i just dont know what to do anymore??
can somebody please HELP!!
thank you
Old Jun 17, 2007 | 09:59 PM
Warrtalon's Avatar
Did you install the stock BOV backwards? The hat should be pointing sideways, not up towards the hood.
Old Jun 18, 2007 | 06:13 AM
EVORaab's Avatar
What exactly is the hat? And how will this effect the flutter?
Old Jun 18, 2007 | 06:17 AM
Juice33's Avatar
My Buschur intake makes a fluttering noise. I didn't install it and haven't really paid much attention to it, I just assumed it was supposed to make that sound for some reason, but it definately flutters. I will have to see if the stock BOV is on the right way. It kind of sounds like the SSQV BOV, weird stuff.
Old Jun 18, 2007 | 06:20 AM
EVORaab's Avatar
Mine is like ridiculously loud and just annoying as hell.
Something is not right...
VRRRR, WHA WHA WHA, VRRRRRR
Old Jun 18, 2007 | 06:23 AM
krazy srt4's Avatar
did u make sure to recurculate it?
Old Jun 18, 2007 | 06:33 AM
EVORaab's Avatar
Everything is setup correctly.
Old Jun 18, 2007 | 04:55 PM
Evo8's Avatar
^^^^ look up pictures of right bov placement. Basicly the top head (where the vaccum hose connects) is supposed to point up (towards you when you look at it)
Old Jun 18, 2007 | 04:57 PM
Warrtalon's Avatar
Did you bother to go look at the BOV? It takes about half a second to figure out what the "hat" is. You can also find a few hundred pics of the proper orientation by searching just to be sure.
Old Jun 18, 2007 | 05:05 PM
glomeli's Avatar
Most likely your BOV is backwards
Old Jun 18, 2007 | 05:15 PM
gixxerman11's Avatar
bov
i think it is backwards tooit should goo pshhhhhhh not psh psh psh
lol
Old Jun 19, 2007 | 11:35 AM
EVORaab's Avatar
you are correct. problem fixed!!
Old Jun 19, 2007 | 11:36 AM
TTP Engineering's Avatar
Of course he is correct.. That is why that call that "turkey flipped".
Old Jun 29, 2007 | 06:11 AM
joon82's Avatar
hmm I'm also getting flutter. i have injen piping
bottom goes to intercooler and front mouth goes to intake right?
getting different bov will get rid of this flutter?
im using stock 9 bov
Old Jun 29, 2007 | 09:23 AM
BBS's Avatar
BBS
No. The piston should be facing the UICP and the mouth where the boost pressure is release should be facing the turbo inlet piping. You're getting flutter cause if it's backwards the valve is constantly opening and closing to let off the boost pressure.
