Evo only running at 11volts
Old Jun 23, 2007 | 01:37 PM
Smokin Evo's Avatar
I charged my battery and it only runs at 12 volt even at 7800 rpm's. If i let it sit for a couple days it goes down to 11 volts and then 10 until it wont start anymore. Now as long as the car stays running it wont die, but when I full throttle it is keeps hick uping. My first thought is obviously a charging problem with the alternator, but the car only has 16,000 miles on it. Can some one shed some light on this for me.
Old Jun 23, 2007 | 02:41 PM
NeostreamGSX's Avatar
bad voltage regulator in the alternator
Old Jun 23, 2007 | 02:46 PM
FastAttack's Avatar
what he said
if not double check the grounding of your car
I would just take it the dealer anyhow if you still have warranty
Old Jun 23, 2007 | 02:55 PM
badstainless's Avatar
Agreed! Check ground as well!
Old Jun 23, 2007 | 10:00 PM
TunerHead24's Avatar
alternator
Old Jun 23, 2007 | 10:04 PM
1BAD4DR's Avatar
altenator bator!!!
Old Jun 23, 2007 | 10:06 PM
hkfeet's Avatar
check the fuse on positive connector or bad alternator
Old Jun 23, 2007 | 10:11 PM
Originally Posted by 1BAD4DR
altenator bator!!!
lol
Old Jun 23, 2007 | 11:43 PM
W0459732's Avatar
whats it suppose to run normally? 14-16?
Old Jun 23, 2007 | 11:55 PM
whoang40's Avatar
my gauge reads 14.5 V at idle with no accessories on, but stays stable around 14 most of the time.
Old Jun 23, 2007 | 11:56 PM
W0459732's Avatar
well thanks, i guess mine is fine then, it should be the car has 1200 miles on it.
Old Jun 24, 2007 | 12:37 AM
14500rpm's Avatar
Might be a bad cell in the battery, or the alternator, or both. If the regulator (I guess this is built into the alternator?) has gone bad then it can screw the battery as well by overcharging it, I've had this happen on a couple of motorcycles.
Old Jun 24, 2007 | 12:40 AM
grazzo77's Avatar
Uh maybe you just got a special version! ; )
Old Jun 24, 2007 | 12:56 AM
Btung4231's Avatar
lol at warranty.
Old Jun 24, 2007 | 11:38 AM
14500rpm's Avatar
+1 but if you have no/few mods it might be worth trying anyway, it won't cost anything for them to say no.
Alternator should be a reasonably easy job you can do yourself on most cars.
