Need quick help on CAM install
Old Jun 24, 2007 | 10:18 AM
belizelittle39439's Avatar
Guys!!
I've got the valve cover off and the ex side cam gear off. I can't get the in cam gear off though. I removed the 14mm allen bolt to remove the cover, but what am I missing?! What do I need to do to remove the intake cam gear?
Old Jun 24, 2007 | 12:26 PM
grenade's Avatar
There's a bolt, thats holding the cam gear on the camshaft, i beleive its a 17mm, you need to break that loose by holding the cam from moving, and turn.
Old Jun 24, 2007 | 12:43 PM
OTTOMITSU's VR4's Avatar
I don't get the question, If you have one cam gear off, it seems like you could figure the second one out????
Old Jun 24, 2007 | 01:02 PM
Speed Corps's Avatar
Former Vendor
Did you see the bolt inside?
Old Jun 24, 2007 | 01:03 PM
Former Vendor
Old Jun 24, 2007 | 01:09 PM
Hey guys, I got it. Both bolts were removed on both gears...just that the mivec intake gear was stuck on real good. I tapped it out and off. I just wanted to make sure there wasn't anything special to do given the intake gear looked different from the exhuast gear.
