Head Light Out!!
Old Jul 14, 2007 | 04:30 PM
Huscroft6's Avatar
Head Light Out!!
Question for some of you who are knowlegable about the lights. I woke up and found out one of the lights isnt comming on???? i was wondering if its only a bulb i replace or with the HID units how that works with a light out. It may sound like a dumb question but its the first HID lighted car i have so im not sure how to fix this problem. If anyone has any info on this it would be much apreciated, thanks so much for the help!
Old Jul 14, 2007 | 05:35 PM
4-BNGR's Avatar
check your ground wire, it may be loose.
Old Jul 14, 2007 | 06:09 PM
Huscroft6's Avatar
where would the ground wire be? sorry to sound uneducated but i am horrible with lighting/electronics/wiring/ect. Could someone post a picture or possibly some more info on what to check? or if its a buld to replace?? thanks again guys....
Old Jul 14, 2007 | 07:14 PM
4-BNGR's Avatar
along the inner fender. it will be a wire leading from the light housing that us attached by a screw to the inner fender.
Old Jul 14, 2007 | 09:16 PM
zli05's Avatar
If one of your low beam is out, other than to check the ground wire, you may have to take out the HID bulb and put on another side. If the bulb is still out, you may have a blow out HID bulb. If the bulb is on, then you may have a blow out ballast. You should really try all the connection (ground wire, fuse) first before taking out the bulb.
Hope it help...
Old Jul 14, 2007 | 09:39 PM
Gonzo0991's Avatar
Needs more headlight fluid. autozone has some on sale right now
Old Jul 16, 2007 | 02:50 AM
EvoInvidia's Avatar
check the fuses as well. I really dont think its a bad grounding. What bulb is it anyways? the HID's and regular running lights dont really link unless you rig it.
Old Jul 16, 2007 | 04:43 AM
Huscroft6's Avatar
the only light that works is the high beam and the fog light. i havent had time to check, my car is in pa and im in boston. ill have it in about a week. ill check all fuses and ground wires and go from there. thanks so much.
Old Jul 16, 2007 | 05:15 AM
4-BNGR's Avatar
Sounds like a loose ground wire to me... and the light is not completing the ciurcuit.
Old Jul 16, 2007 | 12:30 PM
SophieSleeps's Avatar
HID's bulbs should typically last for years as there is no filament to break.
Sometimes bulbs are defective and if you're under warranty there is a good chance your dealer will replace it if you understand HID's.
It could also be the ballast.
I don't see why a factory ground would ever come loose.
Old Jul 16, 2007 | 12:31 PM
4-BNGR's Avatar
Mine came loose
kosteniuks17
May 11, 2014 12:49 PM
afeudale
Lancer How Tos / Installations
Nov 5, 2013 09:29 AM
[Neo]
Dec 7, 2007 11:51 PM
TeKiZeRo
Sep 28, 2006 10:58 AM
evo_racer
Mar 18, 2006 01:46 AM
