Blue Racer Wiring
Old Jul 15, 2007 | 09:26 AM
kaonashi's Avatar
anyone? if not i geuss extending the wires it is.
Old Jul 15, 2007 | 01:50 PM
gunhaha's Avatar
Finally finished the install blue race boost intall at noon. I bought extra wires to extend the gauge harness to the radio and to the wiring that goes to the cigarette lighter (behind the shifter).
Gauge reads 17" Hg vacuum in idle. Test drove the car and boost goes up to 18 psi then tapers down.
I like the gauge. It seemed to take forever to install though.
Is it normall for the boost reading to go down at vacuum (15" to 25" Hg) for a bit when you release the throtlle in the highway.
AK - I just bolted the sender directly to the existing bolt that hold a relay in the engine side firewall. Did you use an extra baracket to hold the sender?
Thanks for the help on the wiring.
gunhaha
Old Jul 15, 2007 | 06:03 PM
skywestseth's Avatar
I did something similar with the sender...and yes if you are not boosting it will read in vacuum....good job on the install!!
Old Jul 15, 2007 | 06:25 PM
kaonashi's Avatar
I actually took my radio out today and pulled the harness out that connects to it, and i used 3 basic wires off of it that say "what do you know" Illumination, Ignition/***., 12v batt/memory"
So it basicially easier the mix matching colors
white-orange on harness
red - Yellow on harness
orange - red on harness
Way easier then whate they are listing to use, and the wires even have the proper names that are listed.
Old Jul 15, 2007 | 06:39 PM
Kdash106's Avatar
i used the Digital clock harness for everything, there is 4 wire on the back and that's all u need, easiest install ever!.
Old Jul 15, 2007 | 06:41 PM
msukach's Avatar
Thanks for the intel...I'm about to install 3 blue racers in my gauge cluster (on order)...already have the boost guage hooked up...going replace the stock w/the same sport guages except replace the stock boost w/an EGT.
Old Jul 21, 2007 | 06:49 PM
trinydex's Avatar
has anyone ever plugged the illumination wire into regular 12v power? (nonswitched)
Tommyy
Jan 17, 2016 07:29 PM
Tommyy
Dec 16, 2015 04:12 PM
shirk
Lancer Troubleshooting
Sep 1, 2010 09:58 PM
TREVORSEVOVIII
Jan 6, 2008 10:07 AM
Deepseadiver
Oct 22, 2006 07:40 AM
