aftermarket camgears
Old Aug 1, 2007 | 01:07 PM
playmajohn's Avatar
i was wondering how mnay of you ran aftermarket cam gears, i have hks272s and was wondering if they are neccessary
Old Aug 1, 2007 | 01:13 PM
StevenStarke's Avatar
if your going to tune them on a dyno yea, but usually just the shafts are the biggest gain
Old Aug 1, 2007 | 01:21 PM
heSOshAdy's Avatar
I am also wondering how important cam gears are, I'm about to install some Cosworth Cams....and of course it's going to be tuned.
Old Aug 1, 2007 | 03:05 PM
jason900rr's Avatar
cams themselves are prob the best bang for the buck your gonna do besides a upgraded turbo. your stock turbo dies around 5500-6000, well i installed my hks 280's and the car would keep pulling all the way to my raised rev limiter(7800) . the gears, i have no idea, i would say throw the extra couple hundred and buy the cams, not the gears!!!!!
Old Aug 1, 2007 | 03:50 PM
sonicnofadz's Avatar
If you do buy the cam gears, stay away from HKS cam gears, they have been known to slip and destroy engines.
Old Aug 1, 2007 | 06:05 PM
playmajohn's Avatar
all great info thanks
Old Aug 1, 2007 | 07:27 PM
ImJoey's Avatar
With everything Ive read people seem to get away with not using them.Im planning on running my 272s w/o cam gears as well.
Old Aug 2, 2007 | 06:32 AM
NYEvoguy's Avatar
I ran my car for a year when i did my Cams before i put cam gears on. their is no real gain to doing cam gears unless you do a turbo upgrade or you want to fine tune on a dyno. Make sure when you do your cams that you do headstuds too. A chep mod for a lot of protection.
Old Aug 2, 2007 | 08:02 AM
zsevo's Avatar
how about the fidanza cam gears, anyone have any experience running those, I just got gsc 280s and am ordering supertech dual springs and retainers, and timing belt and was thinking of buying the fidanza gears as well
Old Aug 2, 2007 | 08:28 AM
chuntington101's Avatar
HOW THE HELL CAN YOU SET YOUR NICE SET OF UPRATED CAMS UP WITH OUT GEARS?????
seriouly guys, you will never see the best out of a set oif cams with out cam gears! they let you set them up and if your tuner is good then you will have them right in the sweet spot! stock ones can move/be out. if they are set up you know they are right!
All the big tuners over here use the like of HKS.
thanks Chris.
Old Aug 2, 2007 | 10:35 AM
projekt_shocker's Avatar
+1 i like to know this also.
Old Aug 2, 2007 | 10:48 AM
hearnoevo's Avatar
cam gears
I'm running the cosworth cams with stock valve train and no cam gears. I've had no problems whatsoever on a IX.
Old Aug 2, 2007 | 11:25 AM
NYEvoguy's Avatar
i'm running Comp 272's, HKS cam gears, HKS timing belt, HKS balancer belt and my car runs beautifully.
Old Aug 2, 2007 | 11:31 AM
precisi0n's Avatar
running hks cam gears too, no probs
Old Aug 2, 2007 | 12:05 PM
Luis@TTP's Avatar
fidanza gears are just as good as any others gears out there
