HKS Harness
HKS Harness
Does anyone know if the HKS turbo timer harness fits on an evo ix? I tried doing a search and there were no results. Also, is it completely plug and play or is there going to be some splicing going on? Thanks
This is the part number you will need for the HKS turbo timers. It will work with both Type 1 and 0, and yes, it should be plug and play unless you want to hook up the other features. The only feature I'd recommend to use would be the hand brake cut off. This is when the timer is counting down, and you drop the hand brake, it will shut the car off.
Jerry
The other features are nice. You need a IX ECU diagram to do it right when comparing the install to a VIII. I like viewing my speed in digital MPH, plus all the other features. (shift light, 0-60, 1/4 mile, 1/8 mile, top speed, rpm's, and a speed limit feature my wife likes)
