Which Wideband gauge? AEM/Autometer?
Old Aug 5, 2007 | 05:13 PM
Evoryder's Avatar
Originally Posted by SophieSleeps
Also,
don't forget that none of you really need anything that accurate and it really doesn't matter in the bigger picture.
If you tune yourself, your goal is not for a specific AFR. If you're showing 5 counts of knock throughout the RPM range, hell you may want richen it a tad regardless of what your wideband reads.
How many of you are actually tuning yourself?
I do, and whether I'm tuning using my AEM or my LC-1 it makes absolutely no difference to me.
I tune myself, and you're rigt about it be 100% accurate. I would love for it to be 100% on the money...but as long as i'm within my target A/F i'm good.
Still, conducting a test and not making it 100% fair is not good business...
Old Aug 5, 2007 | 05:17 PM
mac214's Avatar
I had good results with my AEM. Overall, I was really happy with it but I don't have experience with other units.
Old Aug 5, 2007 | 05:19 PM
SophieSleeps's Avatar
Most people/vendors on this forum would do the same.
I have met very few truly "fair" vendors/people who regardless of their vested interest will not bias their threads/posts/"experiments"
Old Aug 6, 2007 | 11:27 AM
klatinn's Avatar
Hi,
I am just curious:
What was unfair about that test?
During the test ALL devices were datalogged from their analog outs, not digitally.
The datalogged voltage values were then translated to AFR values as displayed on the respective units display.
So if a unit said 11.2 AFR ON ITS DISPLAY on calibrated gas with a calibrated AFR mix of 11.76, the datalogged voltage translation was adjusted to be translated to 11.2 as the respective units display said.
This was done with different lab gases as well to eliminate any possible gain errors, reading errors or ground offset effects in the datalogging equipment or hookup.
Each unit was tested with the sensor it came with.
In addition Ben Strader from EFI University was there during the entire test as independent verifier that everything was done fair and square.
Also, the test was NOT conducted by FordMuscle. It was done originally by a different magazine in which Innovate does NOT advertise. They decided NOT to run the article for whatever reason and gave the author a release to sell the article to somebody else, which happend to be FordMuscle.
I don't want to start any new fighting thread, but I just don't like accusations based on groundless conjectures that are distributed as fact.
- Klaus
Old Aug 6, 2007 | 05:21 PM
Evoryder's Avatar
Originally Posted by klatinn
Hi,
I am just curious:
- Klaus
ok....from the point I read "Zeitronix Software = Rating Poor" ...reasons hard to use and read, I stopped and thought...hmmmm ok...Then they rated the installation/setup as hard....I knew something was up...the results from there on hold no water with me.
Like I said, both units are still quality...that test...out the window, do it again so people will stop referring to "The Test" as the absolute word.
Again, I don't care which is better...just do it properly
Old Aug 7, 2007 | 08:28 AM
CaymanEvo3's Avatar
AEM to the fullest!!!
Old Aug 7, 2007 | 08:31 AM
Planet Evo's Avatar
if you want the most accurate and most effective WB on the market...then your only choice should be the Innovate XD16
Old Aug 7, 2007 | 11:02 AM
klatinn's Avatar
Those parts I cannot comment on as they are the opinion of the author. I don't know the Zeitronix software and was not involved in that assesment, so I don't have an opinion.
As you know, opinions are like a***holes. Everybody has one and they all stink.
I just commented on the TECHNICAL aspect of the test.
- Klaus
Old Aug 7, 2007 | 11:30 AM
travman's Avatar
[QUOTE=SophieSleeps;4612427]
QUOTE]
Actually I tune myself and I tune around a specific afr (12.0)....then I build my timing maps around that afr and if i start to knock I will pull a degree of timing before the knock occurred and it usually goes away. I dont start adding fuel to cover up a knocking issue, I like a nice lean afr with a timing map built for that afr.
My vote is the LC-1 its inexpensive and works great....
blackmambe_evo7
Aug 5, 2014 07:46 PM
warrusmc
Dec 13, 2013 04:38 AM
maxroach
Mar 24, 2013 07:48 PM
kyoo
11
Apr 21, 2012 08:21 PM
magyar86
Mar 3, 2009 09:29 PM
