Want to shoot for 300whp
Old Aug 6, 2007 | 08:35 AM
spyder526's Avatar
Ok so right now I have a stock evo with a boost gauge.I want to be putting down at least 300 horsepower what can I do to achieve that.
Old Aug 6, 2007 | 08:37 AM
cpoevo's Avatar
Air filter, fuel pump, injectors, TBE, cams and a tune.
Old Aug 6, 2007 | 08:39 AM
redteam22003's Avatar
For starter, you can click on the search
other then that, you can do the same sh*t everyone on the forums is doing..
Add intake, exhaust, DP, HFC, MBC, IC, injectors, cams, tune
Then sell your car when you are done...
Justindc2's Avatar
u dont even need injectors. ull also need a mbc or 10.5 hotside
Old Aug 6, 2007 | 08:40 AM
goucho's Avatar
SEARCH!!! Seriously. Too many people come on here and don't want to take the time to look through old posts to find out what they need to know. There are probably 1,000 posts with this same subject, so i'm sure you will find what you need by searching. I'm not trying to be a dick, but do a little research first.
Oh wait, make sure you have Volk rims and some coilover before you sell your car
Old Aug 6, 2007 | 08:42 AM
Genesis8's Avatar
Intake, Cams, Tbe, Mbc, and a TUNE...........
Old Aug 6, 2007 | 08:43 AM
AtO-MiX's Avatar
You need cams and injectors for 300whp. I figured a tbe,mbc, air filter,fuel pump and flash/tune would of been good enough for that. Just get one of the staged packages like warrtalons or something.
okay, now that we cover it all, this thread should be lock
Old Aug 6, 2007 | 08:47 AM
sikrsix's Avatar
I was a member for over a year reading all I could before I even made a single post!
you want only 300hp?? I dynoed 303 with TBE, fuel pump, mbc, and an intake..
Old Aug 6, 2007 | 08:50 AM
spyder526's Avatar
ok well i have SEARCHED and I was asking a question and couldnt find an answer....So if people are going to be harrassed for asking a question in general why dont we just shut it down.(Since everything has been covered)
Old Aug 6, 2007 | 08:52 AM
sikrsix's Avatar
Next time you search
TURN ON THE MONITOR!!!!!!!!!!!!!
Old Aug 6, 2007 | 08:59 AM
evokiTaN's Avatar
Don't think cams and injectors are necessary as well.
Old Aug 6, 2007 | 09:03 AM
Warrtalon's Avatar
Hold on, now. There is no way you searched for this and couldn't find an answer. This is the most basic question in all of EvoM. It just means you DIDN'T SEARCH, yet are claiming you did...not good. You also didn't use the newbie forum, which is where this belongs. There's no need to shut down the forum, because not everything has been covered. However, this topic has been covered a few million times, give or take 100,000.
My signature makes it easy...
Old Aug 6, 2007 | 09:06 AM
AL Beans's Avatar
Search Button
