Kinda of a noobie question, Please help me.
Old Aug 10, 2007 | 10:05 AM
COEVOPOWER's Avatar
Okay so recently, i have been hearing a knockin type of noise on my car, well i searched and searched, couldnt find nothin. and i narrowed it down to injectors, I belive there sticking or something, people told me to get injector cleaner, but I wanna know how I can tell if I have knock in the engin.
Old Aug 10, 2007 | 10:13 AM
W_evo8's Avatar
since you drive an 06 I couldn't imagine why your injectors would be bad unless the pumps are contaminated or something which is kind of rare, still it wouldn't be knocking.
We would also need to know if you're stock or not to make a valid answer.
EDIT: duh I didn't read yor signature.
When you get your tune they should be able to tell you if you have knock or not. You could always get logging software.
Old Aug 10, 2007 | 10:16 AM
72Tornado's Avatar
double
Old Aug 10, 2007 | 10:17 AM
72Tornado's Avatar
I'm guessing you mean a ticking rather than a knocking...knock or pinging sounds very different, what you're most likely hearing is the typical 4G lifter tick. I've had it on my car since brand new and it hasn't gone away after nearly 5,000 miles. After reading a lot about it, it's very common to the engine and isn't really harmful. Put in a quart of Marvel Mystery Oil with your next oil change and follow standard Mitsu lifter break-in procedure (if I remember right, slowly rev the engine to 3,000rpm and hold for about 5 seconds - repeat 20-30 times). Apparently that's made it go away for some.
Old Aug 10, 2007 | 10:18 AM
Turbo Meg's Avatar
Remove some of your mods and bring it to the dealership. Do you hear the noise under full and part throttle?
Old Aug 10, 2007 | 10:34 AM
COEVOPOWER's Avatar
It might be a pinging type of noise, but i also get it around, the valve cover too, I dont know. Hopefully when I have some money and get it tunned It will go away or something like that.
Old Aug 10, 2007 | 11:05 AM
COEVOPOWER's Avatar
Old Aug 10, 2007 | 11:11 AM
COEVOPOWER's Avatar
I only hear the noise when the car is idling
Old Aug 10, 2007 | 11:15 AM
impreza2darksyd's Avatar
ticking at idle, sounds normal.
Old Aug 10, 2007 | 11:18 AM
COEVOPOWER's Avatar
Okay it is just loud. i wasnt sure thought id ask, i wanna be sure and not blow my car up.
Old Aug 10, 2007 | 11:47 AM
fugiwara's Avatar
its common on all evo, most likely is valve ticking
Old Aug 10, 2007 | 11:53 AM
PessimiStick's Avatar
Agreed. Evos have a very loud mechanical idle. It used to bug me too, but after listening to some other Evos and being on EvoM for a while, it's perfectly normal.
Old Aug 10, 2007 | 12:14 PM
*Evil Evo*'s Avatar
sweet.. puts my mind at ease a lil as well.. mine ticks at idle
Old Aug 10, 2007 | 12:17 PM
EVO316's Avatar
yep its very common. i've heard it on other evos, but mine doesn't tick (yet).
but you are ok, its normal.
Old Aug 11, 2007 | 03:14 AM
Jakeg97's Avatar
the mitsu knock -just something you live with
and some evos knock louder than others
