New Numbers!!! 384whp/360tq on 20g-9
Old Aug 11, 2007 | 09:49 PM
project VII's Avatar
get a mbc or ebc if you havn't yet. it will help alot
Old Aug 11, 2007 | 11:05 PM
BBS's Avatar
BBS
Worlds best advice right there.
Old Aug 11, 2007 | 11:13 PM
fusionchicken's Avatar
a local dynopack in socal reads sky high...hope that isn't the case with the OP's dynopack.
+5 billion on mod list
i'm guessing:
injectors
fuel pump
catless tbe
intake (or drop-in)
cams
fmic/ic pipes
intake/exhaust manifolds
(basically every single bolt-on's + cams)
perfection if u can get some track time (especially trap speed to validate the power), but maybe that's asking too much
Old Aug 12, 2007 | 12:26 AM
XSivPSI's Avatar
Why don't the power and torque lines cross at 5252 rpm?
EDIT: Never mind, different scales.
Old Aug 12, 2007 | 05:55 AM
sega_yaj's Avatar
good numbers... congrats...
Old Aug 12, 2007 | 06:14 AM
EVOllie's Avatar
im lost, whats a different scale? shouldnt it still cross @ 5252rpm, or is that a dynapack thing? Not a fan of dynapacks so i know nothing about them. somebody school me on that.
Old Aug 12, 2007 | 08:13 AM
Warrtalon's Avatar
No, because the HP and TQ scales are different. Look on each side - you can see the different scales, and that throws off the intersection point. Basically, you're seeing two separate curves on the same graph.
Old Aug 12, 2007 | 08:48 AM
fox2boost's Avatar
can i please see your mod list, im from springfield ma and need a tune bad, i didnt know that ECS messed around with mitsu's. if you dont mind me asking what did that tune run you???
Old Aug 12, 2007 | 02:52 PM
Sir Lancelot's Avatar
Mods are as follows:
20g9-5
Buschur Delux FMIC w/short piping
HKS RS intake w/Apexi induction box
Works BOV
HKS 272/272
Megan exhaust mani
Megan 02
3" TBE - no cats, resonators or mufflers (straight pipe)
Halman MBC @23psi
Old Aug 12, 2007 | 03:07 PM
Warrtalon's Avatar
So this is not a 20g-LT then?
Old Aug 12, 2007 | 06:31 PM
lucky13evo's Avatar
Whats the differnece between those turbos.
Old Aug 12, 2007 | 07:04 PM
Warrtalon's Avatar
Quite a big difference. Search a bit.
Old Aug 12, 2007 | 07:16 PM
Mine is a 20g9-5
Old Aug 12, 2007 | 07:22 PM
Warrtalon's Avatar
That's a ton of power then. Most people don't make that much even on an LT with pump gas.
Old Aug 14, 2007 | 04:32 AM
fox2boost's Avatar
nice numbers
