Pump gas with Xylene= High Octane Fuel
Old Aug 28, 2007 | 12:37 PM
beemerfreak's Avatar
How does it work?
Anything wrong with using it?
Some guy is using it on M3forums.
This is what was posted on M3forums.
Formula #2 - Xylene
R+M/2.........117
Cost...........$2.75/gal
Mixtures with 92 Octane Premium
10%...........94.5 Octane
20%...........97.0 Octane
30%...........99.5 Octane
u can get at any home improvent stores like home depo.
Old Aug 28, 2007 | 12:51 PM
madmax4499's Avatar
it is true, xylene is in pump gas from the start. it is part of the additave package. more is better. not sure if i would go over 30% with out adding a little atf or marvel oil for top end lube
Old Aug 28, 2007 | 12:52 PM
AlwaysinBoost's Avatar
those prices seem low for xylene. When I was mixing xylene & toluine (sp), back in the day before 9/11, it was around $20.00 @ MAB with an account for a 5 gallon jug. Last time I checked about a year ago it was $60.00 for 5 gallons which = $12/gal which is MORE expensive then race gas!
Old Aug 28, 2007 | 12:53 PM
adding oil of any kind will decrease the octain rating of the fuel. in some cases it will be lower then 91 octain depending on how much you add. there was a real good artical in turbo mag a few years ago on the subject.
Old Aug 28, 2007 | 01:07 PM
madmax4499's Avatar
true, in the past i added a table spoon to 5 gal mix. the past is just that. now i just pony up for the race fuel.
Mauricio Evo IV
Feb 2, 2017 01:50 PM
EvolutionRacing
Jan 18, 2016 09:55 AM
Maxdelta
E85 / Ethanol
Jun 20, 2008 11:06 PM
XK120
May 17, 2007 08:29 AM
bishiboy
21
Dec 21, 2004 03:00 PM
