Exhaust leak in catback, how would you fix?
Old Sep 3, 2007 | 10:07 AM
DSMEVOLUTION's Avatar
Ok I have a JIC SS catback on my car. I've had this exhaust on the car for over a year and absolutely love it! Anyways just recently I started to develop an exhaust where the midpipe meets the axle back. This is a slip fit connection. I tried to tighten up the clamp a little bit more and with barely any force I snapped the bolt in half. I repalced the bolt and tighted it pretty hard and the metal clamp started to bend, just where the bolt goes through. Well when all was said and done my exhaust still leaks. It leaks less than before but it still leaking in the same damn spot. I can feel just the slightest amount of exhaust gases passing through. Do slip fit exhaust always have a slight leak?
Old Sep 3, 2007 | 12:17 PM
evo150's Avatar
you could try getting a new clamp or you could also try putting a bead of permatex copper gasket maker on both side of the clamp. here is a pic of the gasket maker youll want to get
Old Sep 3, 2007 | 12:29 PM
Yeah I was actually thinking about using this as a last resort. I would put it on the clamp itself because all that does is squeeze the slip fit together. I would actually put a small bead on the smaller end of the exhaust that slips into the bigger end and then clamp it together. I guess I have no other choice but to try this.
Ted B
148
Jun 5, 2025 01:24 PM
SW20Mike
Oct 13, 2015 07:01 PM
maevo8
10
May 9, 2012 01:30 PM
Jon91TSi
Jul 19, 2007 05:17 PM
drewblueeye
56
Sep 26, 2006 08:09 AM
