Radiator Leak
Old May 8, 2012 | 12:36 PM
maevo8's Avatar
Radiator Leak
Whats up Evom i have came a cross a problem , i noticed when i boost the car i get a coolant leak i have checked all the hoses and made sure everything is clamped down all the way i cleaned up the area where it spilled and drove it on free way come back home and see it still leaking from some where cant find directly where it is coming from , has this happened to anyone before?
I just installed my ef3 turbo about a month ago and thats when it started to happen ..
i will post up some pix to better explain it
Old May 8, 2012 | 12:51 PM
Chef-j's Avatar
Maybe damaged the hose during install. Have you check coolant level?
Old May 8, 2012 | 01:01 PM
AreSTG's Avatar
have you checked your oil for water?
Old May 8, 2012 | 02:00 PM
maevo8's Avatar
coolant level just the over flow tank gets low ,, i havent checked my oil , what do i do just drain it ? could it b that possibly one of the rubber hoses might have a hole ?
Old May 8, 2012 | 02:11 PM
wizzo 8's Avatar
I had this same leak and I thought it was the head gasket for a while but it wound up coming from the turbo water hose. There was a small pin hole in it. Replaced the hose and all good now. Hopefully this is your problem because its an easy fix.
Old May 8, 2012 | 04:14 PM
maevo8's Avatar
koo thanks tahts what ill be doing hopefully that does it ..
Old May 8, 2012 | 06:04 PM
AJCaron12's Avatar
Pressure test the cooling system and inspect where the leak is coming from.
Old May 8, 2012 | 06:22 PM
maevo8's Avatar
looks like it is one of the hoses that connects to the turbo i went out and 2 stepped the car and had my brother look at it.. good thing it was nothing major
Old May 8, 2012 | 06:28 PM
Spec-Ops1's Avatar
Usually that is one of the coolant lines going to the turbo... has happened to a few of the cars I have worked on in the past... and mine even...
Old May 8, 2012 | 09:51 PM
maevo8's Avatar
^^ya thanks for the help guys
Old May 9, 2012 | 01:30 PM
AreSTG's Avatar
nah, just check your dipstick. if there is water in there you'll know. this would jsut be a fast and simple way to see it might be headgasket.
iufan4lifeul
Nov 15, 2007 03:50 PM
TheBlueBlur
Sep 8, 2007 10:22 PM
Evo05lution
For Sale - Cars For Sale
19
Jul 27, 2007 05:27 AM
Evodreamer28
11
Mar 21, 2007 05:11 AM
ries
Nov 8, 2006 12:04 PM
