broken mbc?
Old Sep 11, 2007 | 07:11 AM
cangriracing's Avatar
thanks a lot, will do
Old Sep 11, 2007 | 07:21 AM
mdsevo06's Avatar
Don't forget to re-grease the Spring and Ball, with High Temp. grease.
Old Sep 11, 2007 | 09:33 AM
8thWonder's Avatar
How did it go, Carlos? I suppose this is the reason you called last night? We played phone tag a couple times...anyway, I'd do like the others suggest and clean it and try it out then.
Old Sep 11, 2007 | 10:08 AM
patty AT forge's Avatar
If you see corrosion in the MBC let me know and I will send you a new spring and one of our new ceramic *****. Also check to make sure the small bleed hole is not blocked... it should be on the other side of the MBC from the side port. Its very small like a pin *****.
Old Sep 11, 2007 | 05:57 PM
thanks guys for all the help, problem solved the inside of the mbc was dirty, i cleaned it with alcohol and then put some grease on it and perfect everything went back to normall. It was fun setting the psi back to 23
Old Sep 12, 2007 | 09:48 AM
lemmonhead's Avatar
did you check your wastegate, hook up a press pump and test it out.
