How Much Boost Off 2-Step
Old Sep 13, 2007 | 07:56 PM
beemerfreak's Avatar
Nice 15 PSI isn't bad. My friend has a AMS tune and builds 11psi in his stage 3 IX.
Old Sep 14, 2007 | 01:43 AM
qazsz's Avatar
10 psi @ 6000rpm
Old Sep 14, 2007 | 02:10 AM
E\/0IXG$R's Avatar
Here's mine, stock launch limiter builds about 9.5 according to my gauge.
Stock launch limiter video clip
Old Sep 14, 2007 | 02:17 AM
1NastyMR's Avatar
12-13psi 6,000 RPM
Old Sep 14, 2007 | 03:14 AM
Crosshair123's Avatar
10psi @ 6000
Old Sep 14, 2007 | 04:02 AM
sharkm87's Avatar
wow, i'm only at 5psi 5750...
Old Sep 14, 2007 | 06:54 AM
Kapoosh1's Avatar
8 psi @ 5800
Old Sep 14, 2007 | 07:03 AM
Pure Playaer's Avatar
like i said.. it depends on what the tuner sets it at.
Old Sep 14, 2007 | 08:31 AM
speedfreak0920's Avatar
8psi @ 5500. ams base flash. 12+ is crazy! wish i could do that.
Old Sep 14, 2007 | 08:45 AM
TouringBubble's Avatar
I run ~12 psi @ 5750. A few of the different answers here are correct ... the higher the RPM, the more boost you will build. But, the timing set in your tune can also change the boost. I've built over 14 psi at 5500 before but encountered knock. 12 psi seems to suit my driving style best.
Here is a tutorial I put together for setting up the stationary limiter
Old Sep 14, 2007 | 09:24 AM
Boosted RS's Avatar
Originally Posted by kreionic
10 psi at 6k
that makes two of us
Old Sep 14, 2007 | 10:16 AM
red evo8's Avatar
11 psi @6k if you guys want higher just look up anti lag
Old Sep 14, 2007 | 10:19 AM
El.BlueEvo9's Avatar
Wow , to the 12PSI's and up
Old Sep 14, 2007 | 10:20 AM
AZ EVO IX MR's Avatar
25 psi @ 3600 rpm MoTec
Old Sep 14, 2007 | 10:21 AM
EvoBroMA's Avatar
you guys need to learn the stock ECU!!!!
thanks TB
