Cold Start Up/Idle Problem
Old Sep 14, 2007 | 03:10 PM
estiller's Avatar
Ok, so when I start my car after it has been sitting for a while -typically overnight- it will start surging like it's going to die and then fluxuate back up again. It's in the 1500-500 rpm range, and when I try to give it gas it will bog, or lower the rpm's back down again and act as though it's going to stall. Usually after turning the car off and starting it back up a couple times it will go up to 2000 rpm's and settle back down to 1500 and idle/run fine the rest of the day. Any ideas would be greatly appreciated, and if this question has been posted before i apologize but I couldn't find anything about this topic after looking for quite a while.
Oh and I live in washington state and it's regular temp's outside 50-80 degrees so i dont think weather has anything to do with it.
Mods: Turboback exhaust, Filter, EBC, SAFC NEO
Old Sep 14, 2007 | 03:27 PM
evo150's Avatar
how long do you let your car warm up in the morning before pulling out? when is the last time you cleaned your maf sensor?
Old Sep 14, 2007 | 07:34 PM
krazirob's Avatar
warming the car up is a must. i let mine run from 5-8 min every morning at the least. check connections and make sure there isnt any leaks....
Old Sep 14, 2007 | 07:39 PM
deontae's Avatar
Problem Solved
i had the same problem with my 02 but mine was worse mine actually would stall out on me i took it to the **** at mitsu and the told me some throtle body bull crap and long story short 1500 fix, took it to my local machanic took him 5 minutes to adjust the idle speed with some little tool he had ever since then the car idle perfectly
Old Sep 14, 2007 | 07:41 PM
Dont Try To Run's Avatar
but your car is nothing like ours
Old Sep 14, 2007 | 08:06 PM
deontae's Avatar
aww man i wasent paying attention lol my bad but it might be it
Old Sep 15, 2007 | 07:16 PM
estiller's Avatar
Normally I let it warm up for at least 8-15 minutes before going anywhere in it, I have a remote start so it has a chance to warm up. Im wondering if the Idle Air Valve is sticking or something, and no i havent cleaned the maf sensor, the car has about 30k miles on it should I be needing to do that already?
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
PINK LANCER
Lancer Engine Tech
Nov 9, 2013 08:11 PM
C6C6CH3vo
19
Jul 18, 2011 08:22 AM
runnerguy780
Lancer Troubleshooting
May 14, 2010 10:19 AM
DanJ
Dec 10, 2009 11:52 AM
