heater cable broke?????
Old Sep 17, 2007 | 06:19 AM
deadbeatrec's Avatar
well this morning i went to turn on knob from cold to hot and something broke inside. WTF? has this happen to anyone? so now i have no heat.
since day one the knob was really hard to turn from cold to hot, and i guess it just let loose today.
anyone know what broke? is it a cable?
Old Sep 17, 2007 | 06:25 AM
evopower1021's Avatar
yeah that sucks... there is a bulletin on it but it has to be under warranty for them to fix it. if you look by your gas pedal there is a little plastic gear there that controls the ac or heat. i've been just reaching down there and turning the gear instead of turning the knob on the hvac controller. so unless you wanna spend money to get it fixed you can do that, i've been doing it for a couple years now
Old Sep 17, 2007 | 06:37 AM
im going to call mitsu and see what they say. im pissed.
Old Sep 17, 2007 | 08:55 AM
well called mitsu and they said there is a cable and it could have broke. this sucks. right before winter this happens!!!!!! ahhhhh
hey what gear are u talking about?
Old Sep 17, 2007 | 09:24 AM
if you look next to the gas pedal you will see a white gear that has a cable attached to it, i guess since yours broke it might just be part of the cable. but it you push the gear one way it turns it all the way to heat and if you turn it the other way it will put it on ac. get a flash light and look under there you will see it.
let me know if you need more info
Old Sep 17, 2007 | 09:42 AM
is it under the plastic cover to the right? i havent looked yet im just trying to visualize it.
Old Sep 17, 2007 | 10:21 AM
RnRjames's Avatar
yea the door blend is what breaks the cable to it.
Old Sep 17, 2007 | 02:07 PM
its right next to the plastic cover its not behind it. you should be able to see it without removing the plastic thats part of your center console
Old Sep 17, 2007 | 06:25 PM
BaLListic_EVO's Avatar
ha your lucky the whole ****ing knob on mine broke..... the cable is in tact though... lol
Old Oct 1, 2007 | 09:11 AM
well i turned the gear and i dont think i have full heat. i think the door is getting in the way. so now i think i have to take apart the whole damn dash to get to it. sucks
