turn the boost
Old Sep 17, 2007 | 09:39 PM
striderx88's Avatar
turn the boost
after i got tune for 22.5 psi can i turn it down to 21 psi is that ok?? will it knock??
Genesis8's Avatar
Why would you want to do that??
Old Sep 17, 2007 | 09:42 PM
striderx88's Avatar
just to be safe ]
Old Sep 17, 2007 | 09:43 PM
fromWRXtoEVO's Avatar
No, not at all, it will be safer.
Carlos
eponti's Avatar
I don't think it will but do some logs just to be safe.
Old Sep 17, 2007 | 09:44 PM
striderx88's Avatar
how many clicks on forge controller for 1 psi??
Old Sep 18, 2007 | 04:44 AM
TBSE's Avatar
you will have to watch your boost gauge to find out...
Old Sep 18, 2007 | 05:05 AM
chaz517's Avatar
i dunno you have to click it a couple times and go check, probably 4 though
Old Sep 18, 2007 | 05:22 AM
SuperchargedGTZ's Avatar
im at 22...my tune was at 24psi on 93 and i turned it down a little just to be be safe. I had 0 knock at 24.
Old Sep 18, 2007 | 10:14 PM
TakaseEVOIXSE's Avatar
same here... im tuned for 24psi... but im always at 22psi to be safe. (im always on 93 oct) But i also have zero knock at 24psi, its just the high boost # always make me uneasy! you'll be ok by turning it down it.
Old Sep 18, 2007 | 11:03 PM
striderx88's Avatar
yeah my spike to 22.5 and stays at about 19
Old Sep 19, 2007 | 07:24 AM
silverblacksrt4's Avatar
keep it the way u got it tuned at!
Old Sep 19, 2007 | 07:29 AM
douggsx's Avatar
I just had my car tuned too and now the weather is getting cooler. (boost will go up?) Can someone, preferably a tuner confirm turning down the boost will not mess with the tune and case knocking at all?
Old Sep 19, 2007 | 11:42 AM
NYEvoguy's Avatar
Old Sep 19, 2007 | 11:46 AM
jrsimon27's Avatar
well maybe you wont get knock cause its just 1psi,but remeber that the stock ecu will hit a lower load cell and probably you will get a leaner afr.
