should i switch up my tune for winter??
Old Sep 19, 2007 | 05:48 PM
fox2boost's Avatar
is my car going to be running lean with the colder densor air temps?
Old Sep 19, 2007 | 07:15 PM
gsrboi80's Avatar
I would just adjust the boost as needed
Old Sep 19, 2007 | 07:41 PM
fox2boost's Avatar
If a reputable tuner (vendor) would chime in i would feel alot better
Old Sep 19, 2007 | 08:16 PM
krazirob's Avatar
would all have to depend on the amount of temp drop. for a user fix just lower the boost as needed. but you shouldnt really see yourself running too lean if the everything is tuned right...
Old Sep 19, 2007 | 09:43 PM
madmax4499's Avatar
interested. my s/c mustang had a winter/summer tune.
Old Sep 19, 2007 | 09:47 PM
fox2boost's Avatar
Mellon?????
Old Sep 19, 2007 | 09:49 PM
uSmC_08's Avatar
I'd like to know as well.
****, I'm in SoCal, so I don't think that's a big enough drop in temps?
Old Sep 19, 2007 | 10:13 PM
ray3328's Avatar
no need to change the tune you'll be fine...
Old Sep 19, 2007 | 10:47 PM
Evo_Jay's Avatar
In the colder weather, boost spikes higher, making the load of the car go high into area that may or may not be tuned. If you tuned for, say, 22psi, when winter comes, just make sure your boost stays at 22psi. If it goes higher, lower it.
Old Sep 22, 2007 | 06:18 PM
Mellon Racing's Avatar
no guarantee that it'll be spot on but I do taper the fuel/timing map at higher loads to account for load increase in cold weather. The best thing to do would be to log it when it's cold and see if there's enough knock to warrant some tweaking to dial it back in.
Old Sep 22, 2007 | 10:08 PM
Boltz.'s Avatar
FCOTM Winner
Even if you did go slightly leaner, which you most likely won't if you turn down your boost controller to compensate for the weather, the air is much colder and will have less probability of knock. If your car is tuned well then there would still be a certain margin of safety to compensate for things like this.
