Engine Oil Suggestions??!?
Old Sep 24, 2007 | 03:32 AM
acid668's Avatar
Exclamation Engine Oil Suggestions??!?
I am planning to change my engine oil and some of my frens suggested that i use Castrol Edge 10W 60.. Has anyone used the Castrol Edge before? If so care to give me feedback on it.. If not does anyone have any better suggestions ?? Your help is much appreciated. Anyway my car is Evo 9 Japanese Domestic Model. Cheers !
Old Sep 24, 2007 | 04:36 AM
recompile's Avatar
Castrol makes good oil, but I've never heard of it being used in an Evo.
Use ENEOS 0w50
Old Sep 24, 2007 | 08:13 AM
acid668's Avatar
Thanks for giving your opinion Cookie appreciate it.. I will look into the engine oil you recommended
Old Sep 24, 2007 | 08:28 AM
Chukee_R's Avatar
Why not the recommended Mobile 1 10w30?
Old Sep 24, 2007 | 02:14 PM
Redline-Z's Avatar
Veteran: Air Force
True, and why are you guys talking about 50/60 weight oils?
Old Sep 24, 2007 | 02:42 PM
barneyb's Avatar
The filler cap says Mobil 1 10W-30. That is not a maker's recommendation, that is advertising (by the way, some of the best advertising ever done since most people think it is a recommendation) . The maker recommends pure synthetic 10W-30 and specifies no particular brand of oil.
Old Sep 24, 2007 | 03:38 PM
holler mcdollar's Avatar
^maybe so, but even still you can't go wrong with mobil 1 10w-30...
Old Sep 24, 2007 | 04:16 PM
kaonashi's Avatar
Mobil 1 or AMSoil only in my opinion
Old Sep 24, 2007 | 04:39 PM
4TUN8's Avatar
I run Mobile 1 10-w30...it works good and I'm never low so I've always just stayed with it.
Old Sep 24, 2007 | 04:59 PM
lurkerpika's Avatar
anyone use royal purp?
Old Sep 24, 2007 | 05:03 PM
dazed01's Avatar
I use mobil 1 because it's 20 bucks at walmart for a 5 quart jug. Hard to beat that.
Old Sep 24, 2007 | 05:10 PM
Redline-Z's Avatar
Veteran: Air Force
Around me it just went down to $18.99! I use that and a Mobil 1 filter for $9.99.
Old Sep 24, 2007 | 05:11 PM
Redline-Z's Avatar
Veteran: Air Force
It is good but for the money order some Amsoil. It is better oil and won't turn your engine purple.
Old Sep 24, 2007 | 05:18 PM
dirty0513's Avatar
You also can't go wrong with Royal Purple, if you have the $$.
I go to the dealership to get the factory oil filters and they are priced well at $5.00
a filter. That is 4 dollars less than the Mobil 1 filters. Also the filter includes a replacement seal for the drain plug. A +++++++
Old Sep 24, 2007 | 05:20 PM
MSFIT's Avatar
whats a good weight for the winter? Going to be driving to tahoe a lot this season
