anti-lag help
Old Sep 29, 2007 | 03:37 PM
kaonashi's Avatar
anti-lag help
Alright guys someone has to know how to get this anti lag to work right.
I pulled the ebrake up so it wouldnt move at all. "just to test it, not actually launching or anything"
Pushed clutch in put it in first held clutch down pretty hard, and gave it some gas to about 4k then i gave it the rest of the gas so that it would hit at 5500 where jestr set it, but for some reason it just went past it and almost hit rev limiter. would the E brake have any reason to make it not work also the car tried to move a little bit even with the clutch fully pressed in so i dunno kinda weird maybe my clutch petal needs adjusting.
Old Sep 29, 2007 | 03:44 PM
Warrtalon's Avatar
Are you sure you have anti-lag? I hope not. I think you are asking about your launch control, right? You shouldn't have the e-brake on, but as for moving with the clutch in, that points to a poorly-adjusted clutch.
Old Sep 29, 2007 | 03:55 PM
kaonashi's Avatar
i can fix the petal, im just more worried about the launch control whatever you want to call it.
Old Sep 29, 2007 | 04:12 PM
4TUN8's Avatar
I think a car moving while the clutch is pushed in is a sign of a throw out bearing issue...............I could be completely wrong so dont quote me but I could have sworn that's what they said with my old car.
Old Sep 29, 2007 | 04:13 PM
4TUN8's Avatar
Oh and as WarrTalon stated, the standing rev limit is NOT anti-lag.
Old Sep 29, 2007 | 04:23 PM
kaonashi's Avatar
Ok its trying to do it at 5500 the car only moves when it hits but i think its just jumping cause its trying to do the launch control but its not bouncing off it, it hits once and then goes up
Old Sep 29, 2007 | 04:25 PM
fox2boost's Avatar
You should adjust your slave cylinder asap or you will wear out your clutch because it's half engaged. If you do that and leave the e brake down and you should be fine.
Old Sep 29, 2007 | 04:39 PM
kaonashi's Avatar
did it, doesnt work, my clutch is working fine nothings wrong with it, and its not engauging lol its acting like its stalling for a split second. and it does it exsactly at 5500
Old Sep 29, 2007 | 06:04 PM
kaonashi's Avatar
fixed the issue, the extra plug , plugs onto the fusebox inside the car is wasnt letting it work correctly.
