running lean
Old Sep 30, 2007 | 01:48 PM
TY3IK's Avatar
Smile running lean
Hey guys My car started running lean. My wideband gauge shows up to 17 some times WOT and my check engine light came on which sad running lean. What should I do to fix that problem??? I was tuned by Devo like 3 month ago and it was fine but now it started running lean and I didn't even do anything to the car.
Old Sep 30, 2007 | 01:52 PM
alan678's Avatar
ouch.....stay off the gas man until you pinpoint your issue....
bad/clogged fuel injectors/fuel pump? FPR bad? def sounds like a fueling issue....
Old Sep 30, 2007 | 01:53 PM
sharkm87's Avatar
check everything is still secure all bolts and what not, manifold bolts and all your hoses are clamped tight......possible fuel pump goin bad?
Old Sep 30, 2007 | 01:54 PM
Redline06's Avatar
+1 on checking everything again.. b4 going WOT again.. anything fuel related check it twice..
Off topic but what is the rule of thumb when it comes to lean.. would you say 12.2:1..at WOT?
Old Sep 30, 2007 | 01:55 PM
TY3IK's Avatar
Is it possible to check a fuel pump???
Old Sep 30, 2007 | 01:59 PM
sharkm87's Avatar
well, hopefully you may still have your stocker? can toss it in real quick....i read other post where peoples walboro's go bad....maybe you have a friend will swap with you real quick.
Old Sep 30, 2007 | 02:04 PM
Evoryder's Avatar
how old is your WIdeband? What is the a/f @ idle and cruising?
Old Sep 30, 2007 | 02:06 PM
Redline06's Avatar
Its a good idea to check your sensor as well..
Old Sep 30, 2007 | 02:58 PM
scottatyamaha's Avatar
If you have your boost gauge tapped into the FPR line check to make sure it has not popped off the regulator or the mani.
Old Sep 30, 2007 | 03:28 PM
CrackerJackToy's Avatar
^^^What he said. Make sure the vaccum line on the fuel pressore regulator has not popped off. Easy fix if it has.
