spark plug recomendation
Old Oct 5, 2007 | 01:31 AM
steexz's Avatar
Looking to get new plugs soon, have a TBE, intake, mbc, o2 housing and running 100 octane full time at 27 lbs on the stock turbo.
what plugs would be best and what gap? thanks alot.
Old Oct 5, 2007 | 02:19 AM
J-ROC's Avatar
search...search.....search.... plenty of threads out there about spark plugs.... good luck.
Old Oct 5, 2007 | 02:38 AM
Spazpilot's Avatar
I heard that the Greddy Iridium plugs are the ones to go with. They are gaped closer then the NGK or Denso.
Old Oct 5, 2007 | 03:19 AM
cochrand's Avatar
how often do you guys replace the spark plugs/wires
Old Oct 5, 2007 | 05:16 AM
03SilvaEvo's Avatar
I like to change my plugs every 6000 miles
Old Oct 5, 2007 | 10:06 AM
suprawillis's Avatar
Sometimes it all depends on how your car will react to the plugs. i did an extensive search last week tryign to figure out the best plug. While alot of threads and replies recommended one plug, the other worked better.
My car only has intake, and TBE and it broke up at upper RPM's using BPR7IEX plugs gapped at 28-then 26 and still broke up. So I switched to BPR-7ES and they worked better and were $1.50 each.
Old Oct 5, 2007 | 01:19 PM
DESERTEAGLE50's Avatar
denso iridium power 0.4mm iridium is what i use not cheap..
Old Oct 6, 2007 | 12:17 AM
steexz's Avatar
yea, i searched around, i guess what im looking for is the best budget spark plug that i can find.
Old Oct 6, 2007 | 12:38 AM
chaotichoax's Avatar
evo ix spark plugs aren't cheap I believe around 10-12 bucks a plug is what you are likely to pay for a good plug
Old Oct 6, 2007 | 03:31 PM
that is not always best to be on a budget when it comes to plugs.get the good ones.
Old Oct 6, 2007 | 05:47 PM
[Advance]'s Avatar
Read it in I.T. that Greddy Iridium is pretty good. There's like race and pro.
Old Oct 6, 2007 | 05:58 PM
theEVOdream's Avatar
nothing wrong with the ngk coppers bpr6e's....although they need to be changed frequently.
Old Oct 6, 2007 | 06:07 PM
killakane24's Avatar
it's funny how people rip someone for asking a question just because it might have been asked before. Just answer the guy if you have one and move on...
