Stock BOV. Is this normal? (sound clip video)
Old Oct 12, 2007 | 02:42 PM
  #31
j14mp's Avatar
Originally Posted by suprawillis
Hey guys, I think its backwards
+1
Old Oct 12, 2007 | 02:44 PM
  #32
Kevin Knight's Avatar
backwards the dude i bought my car off of had his on backwards.
Old Oct 12, 2007 | 03:12 PM
  #33
Str8Nasty's Avatar
Bassackwards!
Old Oct 12, 2007 | 08:22 PM
  #34
holler mcdollar's Avatar
wardsback
Old Oct 12, 2007 | 11:03 PM
  #35
XtoEvolution's Avatar
Originally Posted by Shacochis06
tried loosening it up...still same problem
Have you oiled it recently? The oil dried up on mine and it was surging pretty bad. Re-oiled it and it works great now.
Old Oct 12, 2007 | 11:09 PM
  #36
EVO_IX's Avatar
Where would you oil it? I mean what area would you oil it? Mine does the same and I only have 4000 miles on the car. Wha do you mean when its too tight, what hoses would be too tight? I don't understand, I thought it has to be tight so it won't blow the tube off. More info for this problem is appreciated. Thanks!!
Chad
Old Oct 13, 2007 | 01:41 AM
  #37
Skipmaster J's Avatar
regarding the OP - One question comes to mind. You said you had changed evos... shouldn't you have noticed which way the BOV was pointing on that one?
Old Oct 13, 2007 | 06:43 AM
  #38
DSMEVOLUTION's Avatar
Holy crap OP!!! It's backwards aren't you listening??? All you need to do is pull it off and reverse it. You have the release valve port hooked up to the intake. It's won't release that way. Stop listening to the fools telling you to oil it or telling you it's too tight. They truly don't know their a$$ from a hole in the ground. Pull it off the reverse it, I promise all your problems will disapear. By looking at the picture you took you can clearly see it's BACKWARDS....
Old Oct 13, 2007 | 07:01 AM
  #39
A418t81's Avatar
+1, glad somebody else felt similar frustration on this one
Old Oct 13, 2007 | 07:06 AM
  #40
EVIL MR's Avatar
you sir do not need an evo you need a women and a van.
Old Oct 13, 2007 | 09:33 AM
  #41
KS_Evo9's Avatar
I think its all good bro cause when i got my intake it would do that at low low RPM like 2k. Then I got my MBC and it sounded exact the same at higher RPM I think it sounds sex. Some of my friends were like DUDE!!!!! you got a BOV!!!!! I was like na man its the stock BOV the MBC did that..... HAHAHA If it holds boost man ur GG
Old Oct 13, 2007 | 09:57 AM
  #42
kouzman's Avatar
its backwards... !
get an EVO IX bov, the aluminum unit!
Old Oct 13, 2007 | 10:02 AM
  #43
[QUOTE=KS_Evo9;4846128]I think its all good bro cause when i got my intake it would do that at low low RPM like 2k. Then I got my MBC and it sounded exact the same at higher RPM I think it sounds sex. Some of my friends were like DUDE!!!!! you got a BOV!!!!! I was like na man its the stock BOV the MBC did that..... HAHAHA If it holds boost man ur GG[/QUOTE
Compressor surge may sound cool but it has life threatening effects to the turbo.
Old Oct 13, 2007 | 10:43 AM
  #44
suprawillis's Avatar
Jesus chill out already. I was told it was backwards a few moments AFTER I made the post and I went to the garage, grabbed a tool and switched it around so it is all good. After that there were another handful of "backwards" posts before someone mentioned "oiling" it-whatever. You posted on page 3, get with it.
Old Oct 13, 2007 | 10:47 AM
  #45
If you read the first post I mentioned that I had recently sold my previous owner therefor I could not switch the BOV's let alone look at it. However the car was bone stock and i had no reason or desire to examine the BOV. Now my current Evo was mildly modified so there are a few things I needed to address. The BOV being one of those things.
