Stock BOV. Is this normal? (sound clip video)
Holy crap OP!!! It's backwards aren't you listening??? All you need to do is pull it off and reverse it. You have the release valve port hooked up to the intake. It's won't release that way. Stop listening to the fools telling you to oil it or telling you it's too tight. They truly don't know their a$$ from a hole in the ground. Pull it off the reverse it, I promise all your problems will disapear. By looking at the picture you took you can clearly see it's BACKWARDS....
I'll forgive you for the "fool" comment though
my comment might be late, but i had the same problem before... once i fixed it (reversed it) to put in back into the OEM postion, problem was fixed. instead of telling you that it might be backwards, here's a couple pics of how it should look.
cellphone pics.
cellphone pics.
ur correct ab how it should be connected...but look at the pic.. it is connected the correct way.. i think there s crack on the BOV or some kinda leak... change the bov..
varner88
For Sale - Cars For Sale
16
Jan 26, 2009 07:41 PM
suprawillis
For Sale - Wheels / Tires
Oct 29, 2007 07:41 PM
suprawillis
Sep 26, 2007 07:18 PM
