Stock 2 step on 05 evo? has my ecu been flashed?
Old Oct 14, 2007 | 07:43 PM
trboboost91's Avatar
Trying to find out if my ecu has been flashed scince i am not the first owner.
what is the stock 2 step rev limiter set at on a stock 05 evo?
my first step is at like 5900 or 6k my second is at 7900 or about 8k!
sound a little high for stock, no???
Old Oct 14, 2007 | 07:44 PM
moreryce's Avatar
yea... is ur car stock?
Old Oct 14, 2007 | 07:45 PM
bluebanana23's Avatar
It was either 5,000 or 5,500.
Old Oct 14, 2007 | 08:24 PM
ImJoey's Avatar
pre-flash(stock) I was at 5k exactly.....
Old Oct 14, 2007 | 08:25 PM
JohnBradley's Avatar
5000 and 7606 are the stock limits respectively. Who knows what they have done, but someone was in there.
Old Oct 14, 2007 | 08:28 PM
BlackonBlack2's Avatar
thats a good questions i needa check mine, i purchased used as well and i think the ecu has been messed with
Old Oct 15, 2007 | 05:16 AM
well mines definitly higher than 5000 and 7606!
well i guess its been changed.
i wonder what else has been monkeyed with...
Old Oct 15, 2007 | 07:07 AM
i'm maxing out right before 8k and then a big puff of black smoke 7606 on IX right? and 5000 on VIII's?
Old Oct 15, 2007 | 07:27 AM
CrackerJackToy's Avatar
Mine was was thankingfully stock when I bought it. And it was an '03 that I purchased 4 months ago, weird.
Old Oct 15, 2007 | 07:33 AM
5000k?
Old Oct 15, 2007 | 07:36 AM
EvoVIIIJeremy's Avatar
I thought the 2step rev limit on a viii is like 7600?
Old Oct 15, 2007 | 08:43 AM
scottatyamaha's Avatar
Now you know that your car has been modded to hell and back, ragged out and raced and then stripped back down to stock and traded in. More than likley you are only boosting about 12-14 psi too because he took off his boost controller and re-rigged the stock boost control lines and you are only running off wastegate pressure. Sorry but its probably the truth.
Old Oct 15, 2007 | 11:52 AM
grillpt's Avatar
Why don't you just pee in his cheerios... lol...
Old Oct 15, 2007 | 01:23 PM
NYC EVO's Avatar
lol, he just did!
Old Oct 15, 2007 | 05:30 PM
boost guage says i run 20 psi so if it had a controller it must have been removed and returned to stock at least halfway decent. and it came with full exhaust and arc box. why would you remove half the mods and not those? theyre easiest to take off anyways!
