Replace non-ACD transfer case w/ACD transfer case
Old Oct 16, 2007 | 12:17 AM
Bloomie's Avatar
I have a 2003 Evo VIII with a non-ACD transfer case that is on it's last legs. Can someone tell me if I can upgrade to a later model transfer case with ACD? What are the complications?
Thanks for your help.
Steve Moe
Old Oct 16, 2007 | 09:22 AM
oldscholevo's Avatar
a center diff. new wire, acd pump and tank and also a acd computer and a new drive shaft. oh. I think you need a new ecu also. new dash board that will display the setting. maybe a new tranny, new front and rear diff that will work with the acd, i think.
Old Oct 16, 2007 | 09:27 AM
rcheung's Avatar
Steve Moe
Just get a transfercase from shep with an LSD installed.
Old Oct 16, 2007 | 09:31 AM
srt2evo's Avatar
I don't believe it's that involved. Although, the center diff + ECU with a ACD controller is the far least.
Better off getting a 35/65 or 25/75 front to rear(respectively) mechanical diff for some drifting fun on the track. It's much easier and less expensive.
Old Oct 16, 2007 | 09:37 AM
slicedbreadno2's Avatar
+2^
Old Oct 16, 2007 | 09:58 AM
so you don't think you need the acd pump and tank and the wire for it? ok
Old Oct 16, 2007 | 10:09 AM
Jonasan50's Avatar
Dont do it.. Go to Shep...
Old Oct 16, 2007 | 12:06 PM
SeanJhn9's Avatar
i'm actually looking to swap my acd stuff out for a vcd setup for weight savings
Old Oct 16, 2007 | 12:13 PM
jmartinez1170's Avatar
Its not worth it just get a shep rebuild or get a lsd swap which will make you car drive and shift like a champ. When i got my ralliart i said it can be all that then when i started taking sharp turn at a high rate of speed thats where it all paid off.
Old Oct 16, 2007 | 03:51 PM
evosean's Avatar
buy a transfer case for an 04 rs, you get the limited slip front diff. and its not acd... by the way the center diff is in the trans. you would not have to replace it
Old Oct 16, 2007 | 03:53 PM
evosean's Avatar
ohhhh and one piece you would have to replace is the down pipe
Old Oct 18, 2007 | 08:04 AM
Cinci Turbo IX's Avatar
i dont think it is worth the hassle myself
Old Oct 21, 2007 | 08:14 PM
Bloomie's Avatar
Thanks, Guys
You have told me enough to decide that it's not worth the trouble. I already have an LSD upgrade, so I'll stay with the same setup. Now I need to find an economical source for a rebuild. I appreciate your help!
Steve
hutch959
Jan 1, 2017 04:49 PM
lancerrally45
Mar 2, 2016 01:08 PM
An04EVO
Mar 4, 2011 09:42 PM
