So can someone help me here?
Old Oct 18, 2007 | 06:04 AM
epson1's Avatar
I'll sum it up. Bought an evo at like 3 pm. driving it home i noticed my Fuel light, coolant temp and "Lancer" thing didn't illiuminate but the gauges them selves work. Also, the Tach and speedo work and illuminate, i'm thinking its a bulb....
Old Oct 18, 2007 | 06:10 AM
avengerhed's Avatar
It sounds like a bulb...the gauge cluster uses a fiber optic-type way to deliver light to different areas of the gauge cluster. One bulb may light that entire area...or more than one bulb may be out.
I only had my Evo for 10k miles before a gauge cluster light burned out...same on my Avenger, which had a mitsu cluster (amongst a lot of other mitsu parts).
So I take it that you decided to score the sweet deal on the "salvage" evo?
Old Oct 18, 2007 | 06:15 AM
scottatyamaha's Avatar
common thing on a evo
Old Oct 18, 2007 | 06:16 AM
Oh and by the way that will more than likley be the first of many problems you will find with that EVO you bought since it has a salvage title. Good Luck!
Old Oct 18, 2007 | 06:48 AM
04KWAK636's Avatar
Oh man...salvaged title evos i can only imagine what was done to it prior. Good luck though. Just keep up with the maintenance and hopefully everything will be fine.
Old Oct 18, 2007 | 06:50 AM
avengerhed's Avatar
Hahaha, cut the guy a break...jeez. No need to scare him!
It could be in better condition than most of the used Evo's that haven't been in an accident...at least from some of the stories I've heard...
Old Oct 18, 2007 | 06:57 AM
epson1's Avatar
ok so how do i go about fixing it? and its in super good condition. i trust it.
Old Oct 18, 2007 | 07:58 AM
avengerhed's Avatar
You've gotta pop the cluster out...
I don't remember exactly the steps but you unscrew the shroud around the cluster and pop it out. You *may* have to remove the little trim piece where the foglight button is...
