Setting Boost Problem
Old Oct 21, 2007 | 01:41 PM
KS_Evo9's Avatar
Ok guys so I wanna boost 1.5bar. The problem is when I set boost to hit 1.5bar in 1st/2nd gear when im in like 3rd/4th/5th I boost way to much like 1.6bar. When I set boost to 1.5bar in 3rd/4th/5th in low gears like 1st/2nd I boost only 1.3bar. Its getting annoying so do I set it to 1.5 on higher gears and boost lower on low gears or boost 1.5 on lower gears and boost higher on higher gears. GRRR LOL
Help / Advice would HELP ALOT!!!!
4G63T FTMFW!!!
Old Oct 21, 2007 | 02:12 PM
chaotichoax's Avatar
you can't achieve the same amount of boost in low gears that you can in higher gears due to the fact that there is less load
just set it boost what you want in third or fourth
Old Oct 21, 2007 | 02:16 PM
KS_Evo9's Avatar
Alright thanks for your help man.
Old Oct 21, 2007 | 06:05 PM
KS_Evo9's Avatar
All I did was go on the highway and put the car in 6th gear and at WOT to redline it stays at 1.5bar doesnt fall even a tad. So I wanted to see what it would boost in 1st 2nd etc... It still hits 1.5bar but tapers down just a tad do like 1.3 1.4. Think I should just leave it like this that way no matter what load im under it wonte go over 1.5 bar? What do you guys think.
