best turbo feed line location......
hey guys i just installed my new turbo and im trying to figure out where to run my oil feed line. where do you have your feed line going to??
Nubi... you are true to your name. you are starting new threads with the same subject as your old thread.
https://www.evolutionm.net/forums/sh...d.php?t=301937
Have you figured out why you are blowing turbos? How are you "blowing" your turbo every 500 miles?
I imagine blowing turbo after turbo every 500 mi would get a lil expensive..especially 35R's... Maybe you should water cool it or use meth or a more conservative tune. Doesnt sound like it would be hard to make power using a 2.4L with a 35r and EMS.
i have a 35r and i run it like the stock feeds......i have steel lines to the oil feed,water feed, and water return. i cut down my stock return pipe and used oil/fuel resistant pipe to conect the turbo with the return. my water feed and water ruturn are stock locations buy the thermostat.....my oil feed is also coming from the stock location in the front of the block..works great
