Need Help ASAP!@!!
Old Oct 24, 2007 | 04:42 PM
06MRV8Killer's Avatar
Originally Posted by BlackonBlack2
Thanks for not busting my ***** like everyone else is......
No problem, I like to try and help rather the screw someones thread up
Old Oct 24, 2007 | 04:43 PM
Evoryder's Avatar
i have like a year left and stock other then wheels,lights and k&n filter, finally got them to take it and replace the 5th gear, but now the issue is that its my clutch and not my tranny?????
so did they replace your 5th gear? or you just not making sense...
Old Oct 24, 2007 | 04:45 PM
ty423's Avatar
bleed the clutch line...I don't get how not engaging fast enough does anything. It does sound like a syncro problem though. Try double clutching.
Old Oct 24, 2007 | 04:47 PM
BlackonBlack2's Avatar
Originally Posted by mcjonnyp
sounds like a driver problem to me...
The tranny still grinds when in neutral going down a hill and then shifting back into 5th going up the hill... the tech drove it with me in the car and he couldn't prevent it from happing trust me he was tryn to prevent it from happing because he doesn't want it covered under warranty..
Old Oct 24, 2007 | 04:48 PM
haven't replaced the 5th gear yet.. won't because its a "clutch issue"
or your just not making sense
Old Oct 24, 2007 | 04:51 PM
Boltz.'s Avatar
FCOTM Winner
If your clutch is not disengaging properly you will have the symptoms of bad synchros. Your synchros may be bad but if the dealership is telling you its the clutch then its most likely true.
Old Oct 24, 2007 | 04:57 PM
they are sayn its not engaging correctly not sure if disengaging and engaging are different... but just asking...
Old Oct 24, 2007 | 04:59 PM
so everyone jumped on this thread to bash on me, other then like two people who actually helped me out....
Old Oct 24, 2007 | 05:04 PM
boostless's Avatar
Look...If theyre saying you clutch is the issue and you agree that's its slipping then it's time to get it replaced. If after all of that you still have a tranny issue, you'll probably have a better argument. Did you really expect them to spend the $$ replacing synchros if they feel its a worn out clutch? Me either.
Bottom line, replace your clutch then go from there.
Old Oct 24, 2007 | 05:06 PM
I agree with you on that but, i really don't think the clutch is slipping cause you would feel it, its just engaging late... in 1st other then that it holds rev's all the way thru.... but that might be my only way out.. so i'll looking into it
Old Oct 24, 2007 | 05:35 PM
Chemwarrior's Avatar
"you're"
Sorry couldn't avoid it.
As far as your problem. I seriously hope you get the dealership to replace it because mine does the same thing.
Old Oct 24, 2007 | 05:56 PM
Boltz.'s Avatar
FCOTM Winner
There must be a miscommunication between you and the dealer. If they are saying that they will not warranty your synchros and that its a clutch problem it is because it is not disengaging properly.
Decide if you want to keep the stock clutch or go with a twin disk ( I wouldn't reccomend using an upgraded single disc clutch), replace the clutch, THEN if the 5th gear still grinds they need to replace the synchro.
Old Oct 24, 2007 | 06:38 PM
steevo's Avatar
where did you end up going?
I ended up going to Justin Mitsubishi in Cartersville. They are not open anymore. They have moved to Calhoun but will not touch an Evo with mechanical problems. They did, however, replace all four of my calipers with no questions asked.
Oh, and for the record, my clutch was replaced completely under warranty with
11k miles .
Old Oct 24, 2007 | 06:47 PM
11k miles .
wow your clutch???
steevo's Avatar
PM Sent..
