help car started rolling in gear
ok my friend has a steep driveway that i have parked in before.
tonight i was in gear car off and the car started rollling down the hill 1st 2nd and 3rd gear i was like wtf.
car seems to drive fine like it always has. havnet tried it again on his steep driveway.
any idea could it be my clutch going out?
i think thats how manual cars start the car when the ignition doesnt fire up the car..you roll the car in gear and you let go and it starts up...its kinda like the kick start on lower CC motor cycles. and the higher CC motorcycles do the samething.. they roll the car in gear and let go of the clutch and engine starts.. its usually when the battery is out... .. i could be wrong though...
How do you think your car rolls in gear while you are driving it??? Of course it can roll in gear with a steep enough hill or enough force, it has nothing to do with your clutch.
The evo has lower compression than other cars that you've driven. With lower compression engines it's easier to crank the engine over. Thus by leaving it in gear, the weight of the car was turning the engine over. This is why they suggest when you park your car on a hill that you turn the wheel into the curb when you park, also that you set your parking brake.
