Dream setup or future plans for your EVO
Hmm this is a tough one... so many choices. If money was no issue:
engine
JUN 2.2 Stroker Kit
JAM Stage IV Cylinder Head
JUN 272's
turbo
Full Race Twinscroll GT35R turbo kit
Aquamist HFS-5
Suspension
Custom Valved Ohlins Coilovers
Drivetrain
Shep Trans with Ref Process
along with the rest of their goodies
....maybe a sequential shifter thrown in there too
engine
JUN 2.2 Stroker Kit
JUN 272's
turbo
Aquamist HFS-5
Suspension
Drivetrain
dam....ive spent hours upon hours thinking about this exact same thing...my car is black so with that being said..
ap strideseven rims
tein flex/edfc
sway bars
rear strut tower
seibon cf trunk, hood, and lip (hood partially painted, lip fully painted, and trunk left alone, and ditch the wing)
mr headlights cleared, mr tails
HIDs
ams vsr intake manifold
(2.0 L) ams build kit
excedy hd
shep tranny
race fuel map (109 oct. maybe c16)
ams/buschur ignition
......and ofcourse some stickers to add hp
ap strideseven rims
tein flex/edfc
sway bars
rear strut tower
HIDs
excedy hd
shep tranny
I've thinking about what i want to do with my evo for awhile so far just some of the basic mods tbe boost controler fuel pump and intake now im looking to do then injen icpiping kit im not sure on what intercooler i want the ams one but im think i may go with the turbo xs not sure comp 272 cams aem meth inj shep tranny and transfer case for styling i wana do a defi set up for gauges and put a full sparco interior in - i love the evo ii seats and put a jdm rear bumper with VII tail lights black out the front head lights and further down the road upgrade to the tein flex with the edfc.
Cams? HKS 272? Buschur spec?
Exedy twin plate clutch (which one)?
Buschur Racing Manual Boost Bontroller? or other MBC or EBC?
Buschur Racing Fuel Injectors XXXXXXcc? How big?
Buschur Racing AEM EMS FULL Kit? or stock ECU flashing or other? I want to be able to quickly switch between maps for 91 and 100 octane. Is there a unit that will plug in to the AEM similar to the Cobb Accessport to allow me to switch maps without having to have a laptop hooked up in the car at all times?
AEM all-in-one wideband or plug in for AEM EMS if I go that route? or other?
Water/Methanol injection? what brand? safety features?
Coilover brand for street setup?
This is the wish list.
Have you considered the Tilton or Carbonetics clutches?
If you're using an EMS, you should probably opt to go speed density and use boost compensation tuning methods. In any event, you'll probably choose to use a PWM solenoid rather than a manual boost controller, particularly if you want to have multiple maps to switch between.
It sounds like you're not really decided on your tuning strategy though, as you're considering ECULink, Accessport, or the AEM EMS. With ECULink, AEM EMS, and piggybacks like the MAFT and APEXi SAFC, it's all a choice of how much control you really want. There's no substitute for a fully programmable engine management system like the AEM EMS, but it is also the highest cost, and I'm not just talking about money. You'll have to invest considerable time and effort into tuning it properly and that is after you've familiarized yourself with the software and process of tuning the car. It's a hassle, and though some might downplay the difficulty, it is not a trivial thing to dial in a car with a PEMS.
IMO, water/meth is for folks who are looking to extract the last bit of HP from their turbo setup. Either they don't want to spend the cash for race gas and an extra map, they have an overworked turbo (i.e. working outside it's optimal compressor efficiencies), or they really want to get the top numbers out of their car and don't care what the consequences are (additional complexity increases risk).
Coilovers aren't needed for a street setup, but if you're determined to replace the stock dampers and springs, expect to pay handsomely as nothing for less than 1500 will come close to the broad performance of the stock suspension. You could do springs, adjustable top hats, and suspension bushings including the bump steer correction to acheive (or perhaps improve upon) much of the performance gains found on coilovers at a more affordable cost.
As I read through many of these planned setups, I'm thinking that my ideal car would have reliability as the first priority. I would acheive this through simplicity and using a minimal amount of modifications. I'm also aware that my own car hasn't always followed this guideline and I need to re-examine my own setup.
In January I'm picking up an 06 SE from a friend that has:
ETS intercooler
ETS lower IC piping
ETS Intake
Forge Diverter
Meth Injection
Cos 272 Cams
Head studs
Wideband O2
Megan down pipe
Buschur test pipe
Magna flow muffler
Flash tuned and putting down a little over 400whp and 460 ftlbs torque @ 30psi.
I plan on getting the ETS upper IC pipe kit and mini battery and call it a day power wise. I will need to replace the clutch eventually as it is stock. He does not and has not launched the car and he said that he doesn't even go hard in first until the end of the gear to prevent wear on the clutch. I plan on getting an exedy clutch and then working on the suspension setup as it is stock. Probably go with a decent set of coilovers, but nothing super expensive. That will pretty much put the car where I want it to be performance wise. There are always little things here and there to add.
ETS intercooler
ETS lower IC piping
ETS Intake
Forge Diverter
Meth Injection
Cos 272 Cams
Head studs
Wideband O2
Megan down pipe
Buschur test pipe
Magna flow muffler
Get coilovers, strut and sway, wheels, exhaust, cai, and tune for the Porsche, and if I had somewhere at the track to keep them another set of wheels with R-compounds on em. And I'd be happy with that... Which would cost as much as Evo8Emperor's list
This is including what I currently have done
Engine:
Buschur TBE
Buschur test pipe
Buschur cone filter
Buschur LICP
Buschur FMIC
10.5 Hotside
o2 hosuing
APS BOV
Hallman MBC
Walbro 255
Samco intake
Ported manifold
GSC s1
CBRD EcuFlash
Suspension:
Megan Track coil-overs
Buschur rear strut bar
Whiteline endlinks
Custom alignment
Brakes:
Brembo slotted rotors
Hawk HP Plus pads
StopTech Lines
Wheels/Tires:
Enkei RPF1 17x8.5 +30
Falken Azenis RT-615 255/40/17
Exterior:
Siebon front lip
APR rear diffuser
Rexspeed side spats
Rexspeed oil cooler duct
OEM ventshades
Interior:
Recaro Pole Position seat
Sablet Harness's
M1 harness bar
Engine:
Buschur TBE
Buschur test pipe
Buschur cone filter
Buschur LICP
Buschur FMIC
10.5 Hotside
o2 hosuing
APS BOV
Hallman MBC
Walbro 255
Samco intake
Ported manifold
GSC s1
CBRD EcuFlash
Suspension:
Whiteline endlinks
Custom alignment
Brakes:
Hawk HP Plus pads
StopTech Lines
Wheels/Tires:
Exterior:
Siebon front lip
APR rear diffuser
Rexspeed side spats
OEM ventshades
Interior:
Sablet Harness's
M1 harness bar
500whp on pump with minimal lag. Ported Head, 2.3RR (AMS), HTA35R w/Twin Scroll Hotside and Full Race Twin Scroll Mani, and vertical flow intercooler for better performance. Possible meth kit. Don't know if this would work but sounds great.
I'm enjoying learning the performance dynamics of the car as it sits now: bone stock. All I've really done is a good alignment and sticky RE-01Rs.
In a few years I'll do the common beginner bolt on kit:
-> TBE
-> MBC
-> Custom Flash (probably Atlantic Motorsports)
-> Brake Pads
I got the mod bug out of me with my last car anyway (SE-R).
-> TBE
-> MBC
-> Brake Pads
I'm currently stock. As soon as I sell my Supra, I will probably start down this road:
Time Attack Evo
AMS 2.3RR shortblock
AMS ported/built head
Jun 272 cams
AMS VSR intake manifold and 75mm throttlebody
ETS 3.5" turbo back exhaust with test pipe
880cc injectors
Buschur Racing double pumper fuel system
Buschur Racing or AMS fuel rail
Buschur Racing mini battery kit
Buschur Racing coil on plug ignition
Full Race 3076 twin scroll kit (includes VFMIC, IC piping, tubular manifold, Tial blow off valve, two Tial wastegates, etc.)
CBRD Radiator
Bushwacker transmission build
Exedy Heavy Duty Twin Plate clutch
Megan Race coilovers (track version)
18" Rims (Have not decided brand yet)
AEM EMS or Ecuflash with stock ECU (not decided yet)
Air filter and intake (undecided)
Electronic/Manual boost controller (not decided yet)
Meth/H2O kit (not decided yet)
I'm sure things will change as I go along, but this is the wish list. I know that the enginge/turbo setup is very $$$$$$, but I want everything to be overbuilt and not pushed to the limit. I'm sure there are major faults with this setup, but thats what the forum is for, to point out the problems before you spend the money.
Time Attack Evo
Jun 272 cams
880cc injectors
CBRD Radiator
18x9 volks
cf hood
cf trunk
jdm rear
cf lip
coilovers
sway bars
shep tranny
shep tcase
fullrace twinscroll 40r
2.0 destroked long block built
all the fuel setup
headwork
sum sick cams
ams vsr
750hp++ on race gas
but back to reality
i want 400whp realible on coilovers!
cf hood
cf trunk
jdm rear
cf lip
coilovers
sway bars
shep tranny
shep tcase
all the fuel setup
headwork
sum sick cams
ams vsr
750hp++ on race gas
but back to reality
