Vishnu Tunning Question?
Old Nov 3, 2007 | 11:41 PM
TurboMR05's Avatar
I have an evo 8 MR 05' and i have the stage zero package from vishnu, the exhaust, DP, and testpipe, and the EVO X Flash. I was wondering if anyone has tryed the (Stage One Plus, V390 Package) with the upgraded fuel pump, HKS upgraded cams, and the pre-set cam gears.... I was just wondering if anyone has used it and if they like it or had any problems with it or what? Would this be fine with a stock clutch or should i upgrade my clutch or anything?
thanks,
Old Nov 4, 2007 | 07:13 AM
sparky's Avatar
Did you try posting these questions in the Vishnu subforum? You may receive a better response to your specific questions in that venue.
Old Nov 4, 2007 | 07:30 AM
FedEvo8's Avatar
I'm currently running the XEDE with the fuel pump, cams and cam gears. No problems whatsoever. You can't go wrong with cams, holy crap do they make a huge difference! I highly recommend changing the clutch even IF your Evo is stock! Stock sucks! Also, depends on if you plan on dragging the car, yes, change the clutch.
