rpms between shifts funky
Old Nov 4, 2007 | 02:08 PM
ddubdb3's Avatar
It started a couple weeks ago. But under hard or mild acceleration between shifts my rpms will shoot up about 500 or more rpms...? The throttle isn't sticking my vacuum/boost shows regular...any ideas on what it could be??
Old Nov 4, 2007 | 02:17 PM
Redline-Z's Avatar
Veteran: Air Force
It's just you pushing the clutch in while the turbo is still spooled or your foot is still on the gas. Don't worry about it unless it is slipping in gear.
Old Nov 4, 2007 | 02:27 PM
Chemwarrior's Avatar
It's normal.
Old Nov 4, 2007 | 02:34 PM
amscrazy's Avatar
=Throttle Hang alot of evos got it
Old Nov 4, 2007 | 02:51 PM
Is there a cure for throttle hang though?
Old Nov 4, 2007 | 03:12 PM
Redline-Z's Avatar
Veteran: Air Force
Yeah lay off the gas earlier and not at the same time.
Old Nov 4, 2007 | 03:44 PM
ddubdb3's Avatar
What is throttle hang exactly? How can it be fixed? The car never acted like this before even with haaard acceleration so I'm thinkin something has slack or something....
Old Nov 4, 2007 | 03:47 PM
bluebyu36's Avatar
when i changed my mass air and blow off valve i never had that problem agian
Old Nov 4, 2007 | 04:45 PM
filter's Avatar
lol i was about to ask about this after a curvy road we went on. first time i really pushed my car to the limits.
Old Nov 4, 2007 | 05:28 PM
That's actually incorrect. Here's a thread I found that explains it better with a possible cure.
https://www.evolutionm.net/forums/sh...ttle+hang+cure
Old Nov 4, 2007 | 10:01 PM
72Tornado's Avatar
Friend of mine thought it was just flywheel inertia...I dunno. I've had it on my car since day 1.
Old Nov 4, 2007 | 11:26 PM
ddubdb3's Avatar
i dont kno i tested it again today. hard accel then i clutched in and paused before i went to the next gear and theres a slight delay before the rpms will shoot up..it makes slammin gears kinnnnda hard way to much shock...
Old Nov 5, 2007 | 11:43 AM
Burklow's Avatar
I noticed it a handful of times as well and changed the timing of my shifts slightly and haven't had it since. Either what I did work or it fixed itself. When you floor the gas, don't try to shove the pedal through the firewall with all your might. That MAY be what is causing the throttle to hang a little, but I'm no expert on the problem and I don't know how you drive either.
Old Nov 5, 2007 | 03:40 PM
gsrboi80's Avatar
Does'nt happen anymore since I replaced my clutch and flywheel. Went with a 10.5lb flywheel from Gruppe S and clutch is a ACT HDSS
Old Nov 5, 2007 | 03:58 PM
Redline-Z's Avatar
Veteran: Air Force
A lighter fly will obviously lose RPM faster than the stocker. That is my diagnosis
