Taillight being funny!!! anyone knows this?
Old Nov 4, 2007 | 11:21 PM
evoamac's Avatar
Ok here i'll try my best to describe the problem.
When headlight is OFF: Passenger side tail light doesn't work while braking
WHen headlight is ON: All (4) taillights are ON, But still the same one won't turn brighter when braking.
So, i I figure it's not the light bulb, what could it be. thanks a lot
Old Nov 4, 2007 | 11:33 PM
VTEC_this's Avatar
a short in your harness maybe
i could be wrong though
Old Nov 4, 2007 | 11:42 PM
evoamac's Avatar
i kindda checked all the harness related to lights, they looked fine, btw, don't even know how the hell do i remove the third screw to take off the taillight assemb.
Old Nov 4, 2007 | 11:43 PM
VTEC_this's Avatar
wish i could tell you dude cause ive never messed with any of that on my car
Old Nov 5, 2007 | 04:39 AM
desertstormer's Avatar
Bulbs in your tail light are "double contact". In other words, when your lights are on, one filament in the bulb is working. When you brake, the other filament works as well, so it seems brighter.
Change your bulb, and you should be good to go.
Old Nov 5, 2007 | 07:22 AM
TouringBubble's Avatar
Exactly ... 2 filaments in the same bulb. The one used for the brake lights is out. Easy fix.
Old Nov 5, 2007 | 07:37 AM
lemmonhead's Avatar
does it matter, just take it to the dealership to fix. end of story
Old Nov 5, 2007 | 08:22 AM
mplspilot's Avatar
I hope you have warranty...
Old Nov 5, 2007 | 12:56 PM
4g63tFan@tic's Avatar
+1 Easy fix.
Old Nov 5, 2007 | 01:07 PM
kaonashi's Avatar
I think its a ground, My headlights did the exsact same thing when i forgot to put a ground on them. Or bulb, plug it into the other side and see if it works if it does work its a ground lose. if it doesnt then its the bulb
Old Nov 5, 2007 | 02:37 PM
urslo4n8's Avatar
just change the bulb thats probably it. Switch it with the other side first though to be sure
