Oil light flutter! PLEASE HELP!
hey guys,
i bought my second evo ix mr, recently, and it has 3300 miles on her.
I started modding the car at 1300 miles with mods in my sig.
i had it tuned by Al of dynoflash.
PROBLEM:
after a few hard pulls on the highway, when i come to a stop and let the car idle in neutral, my oil light comes on and flutters really fast.
i checked oil and it is full and i just had an oil change 400 miles ago at the dealer.
also, my car has a really choppy idle (stock cams). It will idle at 900 rpms and every few seconds it will drop to 500 rpms and back to 900 and when it drops the oil light will flutter on/off.
the idle im assuming is because of the HKS RS intake or something...
but why is my Oil light fluttering on/off continuously after a hard run? it flutters fast enough that it almost looks lit up solid
thanks
matt
PROBLEM:
thanks
matt
Evo's have very low oil pressure at idle,after driving the car hard for any period of time the 10-30 oil gets very hot and very thin. Most people who have a pressure guage will only see 6-10 psi at idle with engine very warm, although some claim to see 15-20 psi i have not seen one yet anywhere near there. your light is flashing because your idle is dropping to 500rpm, get your idle back to 850-950 rpm and your light will stay off.
Work shop manual clearly states 4.2 psi at idle engine warm is all you need so don't panic, your car is fine, Evo's are famous for the oil light problem.
Mine did this and it was the oil sensor, dealer replaced it problem solved. Plus whenever I beat on it a bit when I come to idle at a stop the idle seems a little lower. figured it was common for getting on it for a bit.
J Yim
Jan 25, 2016 01:00 PM
Swashbuckler
74
Oct 20, 2007 12:14 PM
broddey
22
Feb 2, 2006 07:32 AM
