Engine Oil Pressure Warning
Old May 3, 2011 | 08:40 AM
Pitside's Avatar
Has anyone ever had this issue? Only at idle 900-1000 rpm after it is warmed up the oil pressure light will flicker on/off. The car does have 264 cam's and with every lope of the engine the light will pop on then off.
Is this common on a camed motor? Or should I be worried about bearing clearance?
Thanks
Old May 3, 2011 | 09:21 AM
dastallion951's Avatar
first off make sure your oil level is full, if its low under the minimum mark that could be why. Also make sure where your oil filter housing is, there should be a plug nearby that monitors the oil pressure, make sure you have no oil leaks from those areas as well.. start with those then report back cuz its not good for that light to come on.
Old May 15, 2011 | 10:57 AM
My03evo's Avatar
Any update on this? Sounds like a bad sensor (would be better news) but prob low oil pressure from some worn bearings or something...
Old May 15, 2011 | 11:05 AM
brenner's Avatar
search it - has been covered many times
replace the idiot light sensor, and you are good to go. NAPA has it
Old May 24, 2011 | 02:27 PM
awdordie's Avatar
Mine done this after I pulled the manifold and turbo. Turns out it was a little low on oil
Old Mar 4, 2014 | 01:54 PM
Mievo4-8's Avatar
Hi did you get the problem solved i also have this problem
Old Mar 4, 2014 | 02:20 PM
Ag4G63's Avatar
Check your oil level first. It it is full check the sensor. It may be broken, have a bad connection, faulty in some way, etc. I've had this problem before and the sensor was cracked.
Old Mar 4, 2014 | 02:21 PM
Pitside's Avatar
replacing the oil sending unit (oil press sensor) fixed it just fine.
Old Mar 5, 2014 | 12:43 AM
Mievo4-8's Avatar
Kl al try replacing the sensor tday and se how it goes fingers crosd thanks
Ef8b16
50
May 8, 2017 08:56 AM
ninemr
22
May 23, 2014 12:52 AM
dibbywsr
Lancer Engine Tech
10
Nov 1, 2012 07:01 AM
StlEvo05
24
Mar 10, 2012 08:31 AM
Johnr352
Dec 23, 2010 07:20 AM
