boost flutter??? help please
Old Aug 23, 2006 | 07:31 PM
AZ EVO IX MR's Avatar
05 evo gsr
The car has been acting strange after boost controller install. First was an Hks evc. That is when the flutter started. When on the gas at any throtle the boost flutters. Sounds like the bov is consistently releasing pressure but i have not proven that the bov is the source.
After the first evc a second was tried and the same thing happened. That evc was put on another evo and the same problem happened. That car had the same mods but no tuning.
Next an avcr was put on and it still flutters. Also we changed the bov to the mr bov and to an aps bov, still the same result. Between putting the evc and the avcr the car ran without flutter but only 11psi.
Recently the ses light came on with a p0139 code and the flutter stopped. The code went off by itself a day later and still no problem. Two days later the flutter comes back.
Any question will be answered we just need to figure this out so feel free to problem solve if i left something out.
Old Aug 23, 2006 | 08:14 PM
SmokinJoe's Avatar
At first read - its sounds like your BOV spring tension was too tight. But that cant be it. Must be a vacuum issue.
Did you remove the pill from the boost line coming from the compressor to the soleniod? Meaning - did you replace the whole line?
Old Aug 23, 2006 | 10:40 PM
all of the lines have been replaced with the ones that come with the boost controller. Also we did a boost leak test and there was no leaks everything held.
Old Aug 23, 2006 | 11:19 PM
~EVILEVO~'s Avatar
DUDE Im telling you its his car, nobody likes to hear it but we have told him how many times now his car is F'd up.. which really sucks
could be, just trying to get different opinions.
Old Aug 24, 2006 | 08:15 AM
dan628's Avatar
When boosting, you should be at full throttle. If you partial throttle boost, especially in 4th or 5th gear, you will get that flutter, since there is more load at higher gears. You will notice the flutter more if you have an aftermarket BOV or intake.
Old Aug 24, 2006 | 08:21 AM
SmokinJoe's Avatar
You can adjust the preload on the spring and dial out any type of flutter. You can also get the boost/vacuum transition to be smooth as stock.
Old Aug 24, 2006 | 08:30 PM
it is at any throttle in every gear. we have also tried about six different bov.
Old Sep 18, 2006 | 10:21 PM
WEVO's Avatar
Did you figure out what happened? My car is experiencing the same thing
Old Sep 19, 2006 | 09:34 AM
kreionic's Avatar
Originally Posted by AZ EVO IX MR
05 evo gsr
The same thing happened on my 03 as soon as I added a mbc it started fluttering. I though it was due to the plastic dv so I got the jdm mr dv and it still continued.I never found out what is was cause I traded it but I was just letting you know I have seen this on alot of VIII
Old Sep 19, 2006 | 09:36 AM
he messed with the settings on his avcr and it finally went away. it started once he put a boost controller on
nspyr
26
Jun 20, 2017 02:08 AM
caduprado
Jul 12, 2015 04:15 PM
08 Evo X MR
Oct 3, 2013 10:41 AM
sonic_evox
11
Feb 27, 2012 07:41 PM
scothu
Apr 13, 2011 09:18 AM
