boost flutter in high rpms
Old Apr 8, 2011 | 11:08 PM
scothu's Avatar
So after my tune I got boost flutter only in 5th gear around 22psi (partial or full throttle). I am tuned around 25 and when it flutters it will take around 3 seconds or so to then jump to 25psi and still flutter... it feels like the car lacks power greatly when this happens...
I went back to the tuner and had my bov crushed a little but that didn't solve the problem. He said there was some compressor serge (around 35k rpm), so my 5th gear map is now downtuned (overdrive.. lol). He said that he couldn't fix the flutter and now my 5th gear pull is even slower but safer i guess. However, now it's happening very slightly in 4th gear (maybe from the crushing of the bov since the 3d mapping only effects 5th gear).
Any ideas? I have gsc s2, stock 8 turbo, 91octane.
Old Apr 9, 2011 | 08:51 AM
vinNybXx's Avatar
you checked for boost leaks right
Old Apr 9, 2011 | 09:03 AM
meckert's Avatar
Replace that BOV for a start--shouldn't have any issues, except maybe on throttle lift at part throttle.
Old Apr 9, 2011 | 09:21 AM
dastallion951's Avatar
tell me why your in 5th gear tryin to pin wot, your luggin the engine around, thats not good, i can under stand maybe boostin between 10-20 psi to pass people...just downshift if you wanna drive like a jackass..ahah...what turbo u running? if its an fp red i can understand some of the surge...
Old Apr 9, 2011 | 11:35 AM
BLKCarbonEVO's Avatar
You are not surging on the stock turbo, I'm willing to bet. Your bov is fluttering and you should gus mod it too. And like already stated.... STOP DOING 5TH GEAR PULLS!!! That is the quickest way to blow your motor ****ing sky high! If you do a 5th gear pull it should be because your redlined in 4th and had to shift into 5th. Other than that, don't do it brother.
Mikey
Old Apr 9, 2011 | 11:46 AM
scothu's Avatar
lol.. well I discovered the flutter when driving on the freeway in 5th.. so i wanted to get it fixed, therefore we did 5th gear pulls to try and fix it.
So i should gus mod my stock (slightly crushed bov) instead of crushing it more?
Old Apr 13, 2011 | 07:42 AM
EvO_vIII_McCoY's Avatar
Mine fluttered a little in 5th gear, boost leak tested it and now its perfect
Old Apr 13, 2011 | 09:09 AM
Crush the bov as far as it will go. The vacum nipple on the top of the bov should be touching the rim of the bov when crushed all the way down. Then do the gus mod.
Also do a boost leak test to make sure nothing else is leaking. A lot of times the vacum nipples on the tb dry rot and start to leak or you have an IC pipe that is not tight. I would use all T Bolt clamps for all your IC piping so you don't have any problems in the future.
Mikey
Old Apr 13, 2011 | 09:18 AM
jameswwt's Avatar
Mikey
Wow!!! Ive similar habit...
Mikey
tsitalon1
61
Feb 28, 2019 02:44 PM
Seth_Horton92
Feb 9, 2017 07:13 AM
J Yim
Jan 25, 2016 01:00 PM
Atlevox
16
Sep 29, 2012 08:54 PM
S2K2EVO
Jan 25, 2012 09:34 AM
