Shifter is VERY notchy and rigid...solutions?
Old Nov 9, 2007 | 06:43 AM
jrsimon27's Avatar
use diaqueen 74w-85w it will shift much better
Old Nov 9, 2007 | 11:57 AM
Dapper Dan's Avatar
syncromesh will shift much better that diaqueen
Old Nov 9, 2007 | 12:55 PM
heSOshAdy's Avatar
Is syncromesh available at the dealer?
Old Nov 9, 2007 | 04:28 PM
mdinubil's Avatar
I know this may sound crazy but since the weather is changing i have noticed the same thing in the morning but my problem was the initial shifting into reverse. My fix has been after letting it warm up for a minute, i shift into other gears before throwing into reverse and have had no problems.
Old Nov 9, 2007 | 04:52 PM
evolved83's Avatar
same thing here... i used to do the same thing on my vw.
Old Nov 9, 2007 | 05:16 PM
avs's Avatar
avs
Originally Posted by spdracerut
Read the owners manual for the maintainceschedule. For all the drivetrain fluids, I believe every 15k for 'severe' use and 30k for 'regular' use. If you haven't chewed through the brake pads yet, expect them to go out around 20k as that seems to be about the average for a daily driven, non-tracked car.
My brakepad are still fine with more than 20k on it. Are they suppose to make a noise when the pad is running low ?
Old Nov 9, 2007 | 07:06 PM
holler mcdollar's Avatar
^other than physical inspection, yeah.
when the pads are wearing and you hear that metal-to-metal squeak when braking, yeah, it's time to change them.
Old Nov 9, 2007 | 09:49 PM
kilgoja's Avatar
mine evo ix mr was the same way until i had about 10,000 miles on it...then it finally started shifting smoother......now i have about 20,000 on it and it's smooth as butta....just don't try to force it into gear.....this is the first car i've ever had that requires a break in for the gear shifting...lol
