next step
Old Nov 20, 2007 | 06:14 PM
evo8nyc's Avatar
next step
so basically ive got the basic done full 3"TBE intake tune boost controller and gauge. So now im looking to see what you guys think should be my next step
Old Nov 20, 2007 | 06:23 PM
drano7823's Avatar
I would look into some cams and a Walbro 255 fuel pump
Old Nov 20, 2007 | 06:25 PM
evocanival's Avatar
^ yes sir
Old Nov 20, 2007 | 06:26 PM
evocanival's Avatar
oh and a re-tune for the cams
Old Nov 20, 2007 | 06:28 PM
evo8nyc's Avatar
oo yea i forgot i got the walbro fuel pump, with the cams do you think i should install seals and retainer im looking into cosworth cams
Old Nov 20, 2007 | 06:39 PM
gsrboi80's Avatar
Depends on how far you want to go. Cosi should tell you whether you'll need to upgrade your springs and retainers.
While you in there valve seals and valves?
Its up to you and the plans for your car
Old Nov 20, 2007 | 06:50 PM
evo8nyc's Avatar
yea i was just thinking since im going to be in there just do everything
Old Nov 20, 2007 | 06:54 PM
gsrboi80's Avatar
I did. But it means pulling the head if your doing the valves and valve seals. If you just do the springs and retainers you dont need to with the proper tool.
Oh and either way you decide to go do the head studs to insure high and happy boost. Even though Ive yet to see a head lift. It has been done
Old Nov 20, 2007 | 07:02 PM
evo8nyc's Avatar
so ill b fine with the retainers and springs? and yea headstuts a most
Old Nov 20, 2007 | 07:29 PM
gsrboi80's Avatar
Yea you'll be fine
Old Nov 20, 2007 | 07:42 PM
CrackerJackToy's Avatar
Go with HKS 272 Cams, or 280s depending on what your going to do in the future. I went with a 280/272 setup. DEFFINETLEY get the walbro 255lph, cams, and maybe even head studs if you plan to run alchy. Headstuds arent really needed, but some like to say its just extra insurance.
Old Nov 20, 2007 | 07:50 PM
evo8nyc's Avatar
yea thanks for the help down the line i plan on getting a bigger turbo setup
Old Nov 30, 2007 | 09:04 AM
(GSX95)'s Avatar
X2
Old Nov 30, 2007 | 09:12 AM
hksevoix's Avatar
wideband & walbro
