evo problem on the highway
yeah when the car over boost's the car will knock if there is too much air (lean) so the ecu pulls timing or fuel to correct the problem. watch your gauges (a/f, boost) and get it tuned or at least a base run to see where your numbers are at........
wow we have 15 noobs trying to answer
he's simply getting boost cut because of the weather. flashes disable it, quite simple to do if youself actually if u get ecuflash software
shuttlegoose.... its NOT too early on a stock 9. around the RPM u mentioned where u received boost cut is where it spikes. by top end you will be back down roughly 2-5 psi (depending on ur car).
ok thats what i was thinking, i will deff get a tune then, and change my plugs while im at it i guess, i got on it a little bit the other day and it didn't do it, maybe it was just because it was so cold out.
The Newbie title has nothing to do with the person behind the keyboard. We have a lot a people that have been on this site for years, but don't reply, start new threads or don't get in to the Forum atmosphere.
In the end, it's up to the OP to decide his next move, with the advise given.
