My wipers are driving me crazy...help!
Old Dec 16, 2007 | 07:28 PM
  #46
kilgoja's Avatar
oh that's the outside...lol...no wonder they look different...i guess i should read a little bit closer huh...oopps
well i took the plastic kick plate off on the inside and checked all of my wire plugs....they all look brand new...no corrosion...just shiny silver..guess i am lucky...i'll keep an eye on it from time to time...everyone should check theirs
are mitsu engineers that stupid?...i mean why not just run the wires through the firewall rather than out the fender then back in through the fender...oh well no problems on mine so far
this drain cowl...where exactly is that...on the bottom right corner of the window?...my fender has a lip on it where the water would go and directs it into the engine area keeping it from going behind the fender...maybe a massive down pour would overflow the lip...i dunno
Old Dec 16, 2007 | 09:28 PM
  #47
850glt's Avatar
I will call my mechanic first thing tomorrow (car was already towed there). I had the same exact issue with the wipers going on by themselves and various lights staying on when they shouldnt have. I'll let you guys know if this fixes it.
Old Dec 16, 2007 | 10:49 PM
  #48
kilgoja's Avatar
found this in another thread...a recall..dunno if it's the same spot
https://www.evolutionm.net/forums/sh...ad.php?t=33419
Old Dec 17, 2007 | 10:12 AM
  #49
Canexican's Avatar
Yeah, let us know how it turns out man...good luck.
Well, that is certainly interesting. Its the same thing that happened to me in my IX. I would imagine that recall would have been dealt with in the VIII's. But who knows, its Mitsubishi, anything is possible.
Old Dec 17, 2007 | 12:17 PM
  #50
MR Turco's Avatar
This is really scary considering how much snow we have been getting. I will have to look into this.
Old Dec 17, 2007 | 05:10 PM
  #51
850glt's Avatar
Well, I just got my car back and the connecter was indeed the culprit. It was COMPLETELY corroded (I will post pics tomorrow). My mechanic did exactly what was done in the pics on page 3. Be warned though, this isnt as easy as it seems as the colors dont match on the connecter (they didnt on mine at least).
Regardless, thanks for your help everyone... this thread should really be stickied - if you have electrical hiccups or your car doesnt start ESPECIALLY after rain/snow there is a 99% chance this is why.
Old Dec 17, 2007 | 05:24 PM
  #52
Canexican's Avatar
I agree with the sticky idea. This is very serious as the car is inoperable when it occurs and there are warning signs to help prevent it. I've seen alot of posts about people having similar symptoms with their cars and have not had good responses as to what the culprit is. I'm just glad that GSRboi was kind enough to let me know exactly what was happening with my car...otherwise I would have probably never figured it out. Where's a mod, lets stick this.
Old Dec 18, 2007 | 04:55 AM
  #53
gsrboi80's Avatar
Glad I could help
Old Jan 3, 2008 | 08:05 AM
  #54
06MRV8Killer's Avatar
gsrboi80 - Very good infromation. This is on the passanger side or the drivers side?
I also read something about the grommet that they run the boost gauge vaccum hose through in the RS and MR having the same problem and causing water to get inside the cabin as well. Does anyone know anything about this?
Old Jan 3, 2008 | 08:39 AM
  #55
gsrboi80's Avatar
This is on the drivers side. What you are refering to is indeed on the passenger side. That was allowing water to soak the carpet.
This issue however directly effects the harness/plugs behind that drivers side kick panel by your left calf
If you follow that harness up you will see it goes through the inner fender and into the engine compartment. Simply remove the rear half of you drivers side plastic fender well (From the outside) and you will se the harness
Old Jan 3, 2008 | 09:10 AM
  #56
Ok got it, that bish is gettin selaed up this weekend! thanks again
Old Jan 3, 2008 | 03:04 PM
  #57
kilgoja's Avatar
where does this come into the car at?...i haven't noticed any wet carpet...just want to know so i can also keep an eye on that one
Old Jan 3, 2008 | 03:59 PM
  #58
gsrboi80's Avatar
Follow the lines for you factory Boost gauge where that goes through on the passenger side is where most have seen the water on the floor .
The corroded pin problem is the harness behind the front drivers fender accessed easily by removing the back half or so of the drivers front plastic inner fender well youll see it go through into the inside cabin
Old Feb 6, 2008 | 06:34 AM
  #59
fkw958's Avatar
Sorry for bumping this old thread. I had the wiper problem a few days ago so I went ahead and looked at the top left connector (the big white one). The 4 bottom wires were corroded so I hard wired those and removed the connector from the bracket and tucked them somewhere higher up so water won't end up in the connector. I didn't have time to properly seal up that grommet or look at other connectors because it was snowing like xxxx. Now this morning my right turn signal is acting up. Its constantly on but not blinking. When i turn the switch it alternates between bright and dim but does not completely go off. I just want to make sure this is also because of the water through the grommet. If it is then i'll just get some silicone and head to my mechanic this afternoon after work. Thanks in advance!
Old Feb 6, 2008 | 06:56 AM
  #60
gsrboi80's Avatar
Youll need to hard solder all of the wires mainly in the big white and black connectors to ensure no problems in the future and yes seal up the grommet ASAP
