IX front bumper install
sorry to ask a simple question guys, but I was going to buy a IX bumper to put on my VIII and need to know if I need anything other than the bumper skin itself.
Its been a long time since I removed the VIII bumper, as I recall there isn't anything special in the way of brackets to make the install. Is there with the IX?
thanks
thanks
yeah I would think the bumper on either car would not be an issue, but I wonder are there a lot of brackets and mounting bits that I don't have?
buying a new skin so it won't have anything along with it
you have to buy the rivets and such but you use the same mounting bar as the stock one. you just drill the holes to match the holes perfectly. really easy. the hardest part is painting it actually
i don't think it's a direct swap. the IX bumper requires a IX beam, and radiator support. if you check here on gruppe-s website
http://gruppe-s.com/Evo/evoext.htm
and click on the Evo IX bumper, it'll say USDM or JDM Evo IX bumper requires a Evo IX beam and radiator support.
There are alot of parts needed to have a fully complete IX bumper aside from the skin. Very few parts from the VIII can be transfer to the IX aside from the screws and bolts. Once you get all the right brackets and such, there is no drilling or retapping to mount it. It mounts to the same holes as the VIII.
It is a direct swap. Not sure about the front crash beam cause I don't run one. You need alot more than just the bumper skin. A few hundred dollars in mesh, bolts, suports, ect...... then paint match. Try and find one used cause it's a huge pain to by everything piece by piece (I know cause that's what I did). Do a search there's like 10 threads about the swap.
