Run with only 3 cyl
Old Dec 23, 2007 | 10:04 PM
Evo8motorS's Avatar
Run with only 3 cyl
Hi guys
I hope this thread will help me.
My problem is when I start my car, it sound like a subaru
I remove all sparks, spark 2,3 and 4 is in normal color and the spark 1 is Black.
I decide to change the wire spark plug and the two ignition coil, But the problem is still here.
Than I made a compression Test on each cylinder and the resut is 11 bar +/-0.2 for all
after the test I decide to change all injector But The car still run on 3 cylinder.
I have an EGT sensor on the manifold ( the hole is on the cylinder 1)
and when I start the cear the EGT gauge stay on the 0.
So now I need some help so I you have any idea let me now
Old Dec 24, 2007 | 11:03 AM
Evo8motorS's Avatar
any idea ??????????????
Old Dec 24, 2007 | 11:05 AM
zlancer's Avatar
well if u pinpointed it to the #1 cylinder not firing did u try changing the #1 spark plug?
Old Dec 24, 2007 | 11:15 AM
wizzo 8's Avatar
I would use a spark checker to be sure the plug is firing. After pulling number 1 spark plug out does it smell like gas? Is it wet?
Old Dec 24, 2007 | 02:25 PM
Evo8motorS's Avatar
Yes I change all sparks and yes all plug are firing
Old Dec 24, 2007 | 02:29 PM
Curt@MrLed's Avatar
Former Vendor
if its black your injector may be stuck open.. is there gas in the oil.
Old Dec 24, 2007 | 02:31 PM
spumoni1984's Avatar
any tears in the boot? your boot may grounding out along the spark plug housing.
Old Dec 24, 2007 | 03:24 PM
Evo8motorS's Avatar
ok
there is not gas in oil and the boot look good !!
Old Dec 24, 2007 | 10:08 PM
Evo8motorS's Avatar
Bump
Old Dec 26, 2007 | 11:01 AM
Evo8motorS's Avatar
BUMP, bump
Old Dec 27, 2007 | 03:51 PM
vacuum lines, fuel filter, injectors.....
Old Dec 27, 2007 | 03:55 PM
Curt@MrLed's Avatar
Former Vendor
stuck open injector.
Old Dec 27, 2007 | 03:56 PM
Curt@MrLed's Avatar
Former Vendor
stuck open injector. start the car and feel if the injector is clicking. or get a noid tester.
Old Dec 28, 2007 | 12:36 PM
Evo8motorS's Avatar
Stuck open injector??
But mine injector are news RC 750CC
Is it possible the problem come from the ECU ???
Old Dec 28, 2007 | 12:41 PM
Evo8motorS's Avatar
Triple check vaccum lines, all are fit proprely
but do not do a leak test yet
