Can I break my lease? Dealer CAN'T FIX my MPG problem...
I hope they did all the basic stuff (changing plugs/wires/filters) and even checked the O2 sensors. Despite the fact your not throwing a code your sensors could be going out. Mine was having a problem getting going when cold, so I did the rear O2 mod via EcuFlash and the problem went away along with averaging 320 miles to a tank with sensible driving.
I just got my Evo filled up yesterday and did my MPG calculation. Took the number of miles driven and divided by the number of gas that I used.... comes out to 19.8mpg. Not too bad. I just drive it to work like 7 miles one way and around town. Light on gas paddle. I would like to floor it but it's not really worth the cops to be at the right place at the right time... I guess I'll have my days when it comes to summer. Maybe I'll take it to Road America circuit if I can. Anyways, Good Luck on your situation
On the highway I see 26mpg.
The ECUFLash rear O2 hack disables the CEL for the rear O2. You won't need spark plug foulers to run catless. If you have a CEL due to the rear O2 the car is probably dumping in extra fuel.
Checking the cruise AFR with a wideband would be the first thing to check.
Something as simply as a failed fuel pressure regulator can dick up your MPG.
I would think if the car was undriveable and still under warranty if the dealer couldn't fix it you'd have a legitimate case to cancel the lease...but I am fairly sure you couldn't get out it w/o penalty just becuase the gas mileage is BuBitty
